Old 02-09-2013, 08:56 AM
vman1 vman1 is offline
Vehicle: 2012 RAM
vman1 is on a distinguished road
Default Engine noise when cold
My 2012 Ram started making knocking noise when cold, right after RPM drops to normal idle after cold start. It starts when coolant temperature is around 140. Once it warms up completely noise goes away.
I recorded it standing around 4feet away from the right front side where the noise can be heard most.
Dealer said is normal and started 2013 RAM on the lot. It makes some noises too, but not the same sharp knocking.
According to them all HEMI engines make the noise. I have 8600 miles on it.
This noise was not there when I bought it.
Any of you guys have same noise ?
Hope the link works:
http://youtu.be/-ofeF7gOHRU
Thanks for listening and any opinions.
Old 02-09-2013, 09:29 AM
RAM SPORT CREW's Avatar
RAM SPORT CREW RAM SPORT CREW is offline
Vehicle: 2012 Ram Sport Crew
Rep:110
RAM SPORT CREW will become famous soon enoughRAM SPORT CREW will become famous soon enough
I agree that they all make a little tick, but that is a pretty sharp knocking sound. My 2012 doesn't sound that bad. Last night at -13 it had the usual little tick but no where near that pronounced! There are other people on here that had similar issues and there are threads on it, not sure what their outcome was with their dealer but you could search for it I guess
I wouldn't be happy with that sound....
Old 02-09-2013, 10:57 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Sounds like cold piston slap which is due to the engine design using a piston that is short and has the pin high up in the piston which allows some rocking, especially when cold. They do use a moly coating on the piston skirts to reduce this, but it is still going to occur to some extent. How cold is it in your area? I would bring it in to the dealer and have that checked, your gonna have to leave it over night, make sure its a cold one to be sure they hear it. but there's a chance this will be brushed off as normal and they will say something along the lines of "they all do this" Again, JMO
Second thing that comes to mind is a bad manifold bolt, as the engine heats up it will go away, eventually even when hot it will stay, so in the long run you will or might hear it even when in hot mode
Old 02-09-2013, 11:16 AM
Vehicle: 2012 RAM
The coldest weather we get is around 40. It will do it even when it was 65 but the engine was cold (overnight)
I left it at dealer and they have heard it third morning finally and said YES there is a noise. The following was typical "they all do that" after they started 2013 RAM in front of me. It did make somehow similar noise (or it's frequency) but lot lower tone which sounded fairly normal to me. Nothing like mine.
It does not sound like a leaky manifold. That is usually even sharper sound from my experience. My old 02 had that problem. Back two bolts used to loosen up from time to time.
I guess I will have to make them write statement after I pick up the truck saying that sharp metallic knocking noise on cold start is normal to these vehicles.
But I doubt that they will write and sign that kind of statement.
At home the noise will be there every morning. At dealer it took three days and three cold starts. I suspected that they dumped some oil additive in to quiet it down. When I asked they said they wouldn't do that unless I request it. Which brings up another question. Anybody know where can I have my engine oil tested for additives (yes I understand I will have to pay for it). somehow I don't trust this dealer so much. The mechanic that changed lifters at 3700 miles on my Ram due to noise before kept saying that his HEMI is noisy too and that he wouldn't change lifters if he didn't think there was a problem with it.
I had the service manager, one service advisor and mechanic listen to the noise.
Thanks all for any feedback.
Old 02-09-2013, 11:27 AM
Vehicle: .
Rep:4373
First thing, is there another dealer you could go to and get a second Opinion.
Second, you could on your next oil change, if its not full synthetic, change to full synthetic like amsoil and see if your issue goes away.
Third, When you do your oil change contact these guys and get a sample bottle before your due for an oil change, send in your sample and ask to check a) is your engine doing well and your engine, and b) can they detect other stuff in the oil that should not be there. I would even contact them and ask them before hand if this is something they can find out.
http://www.blackstone-labs.com/
I have them check my oil every oil change. worth the extra cost in protection.
Old 02-09-2013, 11:35 AM
clum553946 clum553946 is offline
Vehicle: 2012 Ram Big Horn Crew 4X4
Rep:24
clum553946 is on a distinguished road
If you had the lifters changed, that could account for the noise if they didn't break them in correctly. Lifters that aren't broken in will wear themselves & the camshaft out. Usually you replace both unless things have changed!
Old 02-09-2013, 11:48 AM
Vehicle: .
Rep:4373
Hes got a point, and Even if they broke in the lifters like they should of (1700-2000 rpm, never at idle), they do not always break in well, if they just replaced the lifters the geometry of everything needs to be of greater precision to maintain reliability. Cleanliness, alignment, clearances, journal surface finishes and lubrication must all be controlled more closely then when from the factory and everything in the engine is new, this is why most engine now are broken in at the Factory, we only need to break them in before pulling loads or carrying, first 500 miles.
Old 02-09-2013, 12:17 PM
Vehicle: 2012 RAM
Yes there are few other dealers around. I will take it to next one once this dealer return my truck. They had to do couple other things (repairing two rims they messed up when they rotated my wheels and brakes due to warped rotor due to uneven torque of wheels - yes it is ridiculous). Guess where my not so much trust to them is coming from. Truck has been for 4 days now and I should get it back maybe on Monday.
Thanks for the advice and link to the lab. I will call them and ask if they can detect additives in engine oil.
Old 02-09-2013, 12:34 PM
Vehicle: 2012 RAM
Yes they did change all lifters due to noise at 3700 miles. It was similar noise as I have now only when cold but it was more noticeable on the left side of the truck and now it is on the right side. Hood closed.
The repair report said, replace full set of lifters, two lifters sluggish on idle, replace head gaskets. And misc items like oil, etc.
Old 02-09-2013, 03:45 PM
Vehicle: 2012 RAM
OK so based on your input (and my believe) once they pull heads and start replacing parts, the engine will never be as good as original factory engine ? Unless they replace parts that need to be matched like lifters and camshafts together ? But then they would probably have to do valves and seats and list goes on......
It was making noise back then, so they decided to change lifter. The diagnosis took about 2 minutes of listening and mechanic said it's a bad lifter, ordered new set and did it. Now he is the only one that knows if he changed them all or not. But for sure they did not change camshafts.
I guess I am screwed. Chrysler is no help because they will blindly go with whatever dealer says. So if dealer says that it is normal noise Chrysler will back them up. What do you guys suggest that I should do ?
Ask for new engine ?
