Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 02-09-2013, 03:25 PM
myfirstgoat myfirstgoat is offline
Vehicle: 2009 Dodge Ram
Color: Blue
myfirstgoat is on a distinguished road
Default Highway Vibration
I have a 2009 Dodge CC Sport with 22" Wheels. In the last two weeks I am getting a horrible vibration at 70-75 that makes it feel like the truck is going to hop onto the shoulder. I have had the tie rods in the front replaced, the u bolts replaced on the driveshaft, the wheels balanced, then road force balanced and they could not get good numbers at all. Now bean bags and still the same vibration. Anyone have any suggestions on what to do. The dodge dealership tells me they cannot diagnose because they are not allowed to test drive the vehicle above the speed limit. HELP
Old 02-15-2013, 12:47 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
So are you saying the wheels and tires can't be balanced properly? If so then that is the issue.
Old 02-23-2013, 12:17 AM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Are the wheels hub centric?
"I don't care to hear what your ideas are, mine are better"
Old 04-04-2013, 11:02 PM
2RAMSAM's Avatar
2RAMSAM 2RAMSAM is offline
Vehicle: 09 Hemi Ram
Rep:13
2RAMSAM is on a distinguished road
I agree. Tires, probably the underlying issue.
Old 04-05-2013, 10:26 AM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Go to a good tire shop and then have them follow these instructions. make sure you start by having the right lugs and centric rings for your wheels if you need them.
1. Check wheel for run-out, if more than a few thousandths the wheel is bent, replace it.
2. Mark the wheel AND the tire at the spot of the most weight. Dismount tire from wheel.
3. Place wheel (with TPMS attached) only on the balancing machine and balance the wheel only.
4. Mount tire on wheel with mark from earlier oposite of any weight (180 degrees) placed on wheel.
5. Balance tire and wheel assembly.
6. If assembly still requires excessive weight or wont balance well the tire is bad. Remeber, just because it has tread or is new doesnt mean the tire is good, many things can happen in the moulding and manufactur process to damage it.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 04-11-2013, 08:26 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
6. I
Man that is pretty involved, but I would be pretty impressed if a tire shop went through that much effort to correct a problem, I would certainly be going back.
Old 04-11-2013, 08:47 AM
Rep:256
Not really. That was the process for years and why most tire shops charge so much to "Mount and Balance". Now they just take your money, do the job as quick as possible and push you out the door. Some shops still take pride in their work, if you find one stay with them, even if they charge a little more.
