spyder headlight/HID/high beam issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 02-09-2013, 08:22 PM
topherxx topherxx is offline
Vehicle: 2009 dodge ram
Trim Level: Slt
topherxx is on a distinguished road
Default spyder headlight/HID/high beam issue
So i installed these headlights today with HID for low's and halogens for high's. everything works fine except when the lights are in the "off position" or the "running lights position" once i shift into "drive" the drivers side high comes on, like DRL.
Any ideas on what to do to make that not happen?
Old 02-10-2013, 12:51 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Check your wiring on the drivers side to make sure everything is properly connected, If they are plug and play and you don't have a battery harness connecting lights right to the battery, it may be caused by the HID's not gathering enough power to the drivers light/balast. If that all fails, it could possibly be a bad/ weak balast.
IG:@briley59
Old 02-10-2013, 01:31 AM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Yes, check the connections...make sure they all are tight. I have spyders too and some of the connections between the new harness and the truck plugs were loose and sloppy, so I cut the ends and soldered them. Make sure to use electrical lube on the connections (except from the ballast to the bulbs) to help keep out water and corrosion.
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 02-10-2013, 02:53 PM
Crash Crash is offline
Vehicle: 2016 Laramie Longhorn Limited
Trim Level: Laramie limited
Color: Black crystal pearl
Rep:404
You are from Canada so your highs are supposed to come on when you shift into drive, that is your DRLs. the question you need to answer is why is only one coming on
Old 02-10-2013, 05:44 PM
Trim Level: Slt
yeah it was the passenger side headlight connector, the locking tab was broke, so it was a loose connection.
thanks for the replies guys!!
