Old 02-09-2013, 08:50 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Default Whats the problem?
So I recently had an EGR Valve code come up so I bought a new EGR Valve and replaced the old one. But now I seem to be getting way worse MPG than I was with the old EGR Valve in. Also, though nothing looks different when I rev the engine the exhaust smells much more rich than it did before the EGR Valve switch (only if you are on the outside of the truck, from the inside you dont smell it) Does anyone know what the problem could be? The truck is running fine other than the decrease in MPG and the smell of the exhaust. My driving habits havent changed so I really dont know what it could be.
Supercharged, cammed, other things too!
Old 02-09-2013, 09:12 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
What code number did you get?
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 02-09-2013, 09:15 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
P0404 ITs one Ive gotten before and had to change an EGR Valve back in July. I didnt think the code would come up again but I was wrong so I just went and got a new EGR Valve since its a relatively cheap fix ($40)
Old 02-09-2013, 11:41 PM
RAM EM's Avatar
Color: Grey
Rep:195
Did you disconnect the battery after swapping the valve to clear the memory? Might be worth a shot. Also try disconnecting the plug from the sensor and drive it. You will get a cel, but it wont hurt anything, and see if that helps. If it does you probably have a bad EVP sensor, which I think is integral to the valve on your truck. If so, go back where you got the valve and exchange it for another. Is it mopar or parts store brand?
Also, make sure wiring is in good shape going to sensor.
Old 02-10-2013, 12:54 AM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
I have a Predator tuner and used that to clear the code. From what I can tell the wiring is in good shape with no problems. I really hope its not a bad sensor on the new part, since last time I replaced the EGR valve I had problems with the new part as well.
Would maybe doing a system cleaning fix things? Such as a seafoam treatment or something like that?
Old 02-10-2013, 01:59 AM
RAM EM's Avatar
Color: Grey
Rep:195
Clearing the code won't clear PCM's memory. Since you have a tuner, reload the tune. Seafoam treatment won't hurt, but I doubt it will "fix" anything.
Disconnect the plug and see what happens as far as gas mileage/smell. You'll basically be bypassing the EGR system by doing this. You can clear any resulting trouble codes.
Old 02-10-2013, 11:02 AM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
Ill disconnect the battery today (hopefully) and let you know if I see any improvements
