Old 02-10-2013, 04:40 PM
L0veless L0veless is offline
Vehicle: 2010 ram 1500
Color: zilver
L0veless is on a distinguished road
Default tire pressure idiot lite
had a tire replaced on left front 2 days ago and the low tire pressure warning lite stays on. my displays shows pressure the same as other tires within 1lb or so and it adjusts as the presure changes earlty morning 33lbs
afternoon 38lbs also the left front tire readout is contantly flashing. so Im assuming the tpms sensor is working as it adjusts to changing presure, its between the other three tires in presure being a 1-2 lbs difference in all 4 tires. the tire shop says it should reset after a few miles but its been 2 days. as a note I did believe the shop in the past when I have had a tire changed it did take a few miles for everythign to reset. any help thanks.
Old 02-10-2013, 04:50 PM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
Just swapped out all 4 tires and no flashing lights here. I'd be thinking they damaged your sensor during the swap.
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 02-11-2013, 08:02 AM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
I found that once the pressure drops below the system limits and the light flashes, the tire needs to be filled above the specs (35 psi for me) in order to clear the fault. Just because it increases above the specified psi as you drive does not cancel the fault. The system wants to see you manually install more air into the tire.
Old 02-11-2013, 10:40 AM
Color: zilver
thanks for the input
I will try that tonight.
Old 02-11-2013, 10:50 AM
Rep:1909
Actually, yes, it does clear the fault once the pressure increases above the threshold. The system has know way of knowing how the additional pressure got into the tire, only that it sees what it needs to in order to deactivate the light.
Old 02-11-2013, 10:54 AM
Rep:1909
Have you checked the spare? If your truck monitors the spare and it gets low, the light will come on.
Old 02-11-2013, 01:18 PM
GearHd6's Avatar
Color: Mineral Gray
Maybe mine never got back over 35 psi then. I normally run my rear tires down around 32 psi but it got cold and they dropped to about 28 psi, then the light came on. As I drove it didn't get back over 35 psi I guess. I needed to manually put over 35 psi in the tire in order to clear the light. Once I cleared the light I could drop it back to 32 psi.
It seems as though you need to get below 30 psi to turn the light on and back over 35 psi should shut it off. That would be a 7 psi swing to turn on and turn off without adding air manually. That's a large swing....
Old 02-13-2013, 08:20 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
If it's the spare, I would inflate it to just under 40, it's under your truck, no harm until it's needed, then pull out your tire pressure gauge and deflate it equal to the other tires.
Old 02-13-2013, 09:37 AM
Rep:1909
The pressure thresholds can be adjusted via factory scan tool.
Rep:1909
That's what I typically do with customer vehicles.
