Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 02-12-2013, 03:39 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
I too have done same thing. I fixed my somewhat limited brain power while changing oil.
I have a white piece of laminated paper that I hang on streering wheel. Its asks me, Drain plug tight? Oil filter tight? Oil in engine? Oil cap back on? Everything wiped off?
I use it like the check off list NASCAR teams use.
It helps me alot. Because "sometimes" I lose my brain power.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 02-12-2013, 07:49 PM
ramit1500's Avatar
ramit1500 ramit1500 is offline
Vehicle: 2012 Dodge Ram Outdoorsmen
Trim Level: Outdoorsmen
ramit1500 is on a distinguished road
Its a good habit to remove oil cap and put over hood latch before draining oil.
Old 02-13-2013, 10:39 AM
Resident Technician
Rep:1915
This is a practice Chrysler teaches when training lube techs.
Old 02-13-2013, 11:01 AM
thebaldguy's Avatar
thebaldguy thebaldguy is offline
Trim Level: Big Horn Crew
thebaldguy is on a distinguished road
I will do this next oil change! Good tip.
Old 02-13-2013, 12:12 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Originally Posted by LeftCoast View Post
You wouldn't need another oil change after just doing it again. Did it spray any in the engine compartment? Maybe clean the engine compartment.
I was more curious about this too. I've had some small block chevy's with open valve cover caps for oil filling, and they would spew oil the moment you fired up the engine...happens more than many think after an oil change...LOL! However, these engines with standpipe oil filler tubes probably don't throw oil because of the location and length of pipe.
Old 02-13-2013, 08:37 PM
roo roo is offline
Vehicle: 2013Express,2014 Charger R/T
Rep:44
roo is on a distinguished road
Originally Posted by RamTech View Post
No need to change the oil again. Any contaminants that may have entered the engine will be carried to the pan via the returning oil and will be picked up and filtered again before reaching any bearings or other components where tiny particles do the most damage.
Filters do have a saturation point, cheap insurance, change the oil.
Old 02-13-2013, 08:45 PM
roo roo is offline
Rep:44
An old buddy and I were going to adjust the hydraulic lifters on the 327 we had just put in his 57 Apache. Little did we know that the throttle on his Holley 4bbl was in a bind and hung wide open.That was about 30 yrs ago and I bet there is still oil up in that car port we were working under!
Old 02-21-2013, 06:57 PM
ramit1500's Avatar
Honda as well I am an acura tech.
