Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Mopar Online Parts - Dodge Ram Accessories!
Mopar Online Parts - Dodge Ram Accessories! Suppliers of Genuine Dodge/Ram Parts and Accessories at wholesale prices. Shop with confidence as all repair parts orders are checked against the VIN provided to ensure 100% accuracy getting you the right part the first time. All items we sell are backed by a 1yr warranty. - Dodge Ram Accessories!
Old 02-11-2013, 07:27 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
Default HOW TO: 2013+ LED Tails into a 4th Gen
This how-to guide was sponsored by Mopar Online Parts - be sure to support the vendors who support our forums and this guide.
Disclaimer: Modify your vehicle at your own risk.
1. REQUIRED PARTS
To complete the installation of 2013 Ram LED tail lights into a 2009-2012 truck, you will need the following:
1.) LED Tails – Available from Mopar Online Parts, who sponsored this writeup.
· Sport LED Tails P/N’s: 68093080AB and 68093081AB (pictured below)
· Premium (Laramie) LED Tails P/N’s: 68093078AB and 68093079AB
2.) LED Tail Pigtail Wiring Harness –Available from Mopar Online Parts.
· P/N 5013984AA – QTY 2
3.) LED Load Resistors (Various Suppliers).
· 50W6OHM Resistors – QTY 2
4.) EV6 Male Connectors – Available from InjectorRX (www.injectorrx.com).
· Bosch EV6 Male Connector – QTY 2
5.) H13/9008 Male Pigtails – Available from Autolumination (www.autolumination.com).
· Male Pigtail – QTY 2
6.) Approximately 2’ of 16ga insulated stranded automotive wire.
2. OPTIONAL PARTS
The following parts are optional, and not required. You may choose to use these depending on your preference.
1.) LED Tail Pigtail Wiring Harness (Junkyard)
· This harness is the same harness that was used on the ’98-’03 Durango, ’04-’09 Durango, ’96-’00 Caravan/Voyager, and potentially others. Be sure to get as much wiring as you can from the donor vehicle – at least 6 inches or more.
2.) Aluminum Plate
· LED Load Resistors can get hot, it is recommended you mount them to a metal surface. I chose to mount the LED Resistor to an aluminum plate, which I mounted to the truck. Aluminum is a far better heat sink than steel.
Rep:154
3. ORGANIZE WORKSPACE
Start with a clean work space. Below is the layout of the parts I started with, identified by number below.
4. WIRING
To install the 2013+ LED tail lights, a jumper harness must be made to connect the 2009-2012 wiring to the 2013+ LED tail lights.
Before we start making the harness, it is important to note how the 2013+ LED tail lights function. Below is a diagram of the functions of each of the pins in the 2013+ tail lights:
4.1 LED TAIL SIDE WIRING
If you sourced the LED pigtail from a junkyard, you will need to move one pin, and remove and discard another, as they are not all in the correct location for the 2013+ LED Tail Lights. Below is a picture of the contact that must be moved and removed and discarded.
To remove a pin:
1.) Remove rear cap with a pick or small flathead:
2.) Remove rubber insert:
3.) Lift up on blue connector retainer with a pick:
4.) Insert small flathead or allen key to release plastic pin retainer.
5.) Remove wire.
6.) Re-insert wire to correct location.
Rep:154
4.2 TRUCK SIDE BRAKE/TURN SIGNAL WIRING
On the 2009 – 2012 truck, there is a separate plug for the brake/turn light and for the reverse light. This section covers the brake/turn light wiring required.
1.) Take the H13/9008 male connector and grind off the locking tab. This will allow the connector to fit into the truck female connector.
2.) Leaving yourself approximately 6-inches of wiring, you will want to connect your LED Tail Pigtail wires to the H13/9008 male connector, as identified below.
3.) At this time you will need to wire up a load resistor to prevent your 2009-2012 truck from showing a “Bulb Out” error message. The load resistor must be connected between the ground and brake/turn driver.
a. Extend the power leads from the load resistor to a length of approximately 6 inches.
b. Connect one side to ground, and the other side to the brake/turn signal wire.
4.2 TRUCK SIDE REVERSE LIGHT WIRING
On the 2009 – 2012 truck, there is a separate plug for the brake/turn light and for the reverse light. This section covers the reverse light wiring required. The 2013+ LED tails use a 7443 reverse light, which is more powerful than the 921 style light used in the earlier trucks, which means the existing reverse wiring must be adapted to the 2013+ LED tail wiring.
The 2013+ LED tails share a common ground between the reverse light and brake/signal lights, whereas the 2009-2012 trucks have separate ground for the reverse and brake/signal lights. Due to this, the ground from the 2009-2012 reverse light will not be used for this installation.
1.) Take the male EV6 style connector, and connect the reverse light driver as follows:
Old 02-11-2013, 07:28 PM
Rep:154
5. INSTALLATION
1.) Be sure vehicle is in park, set parking brake, and disconnect negative terminal from the battery.
2.) Plug in the truck side brake/turn connector, making sure that you plug it in the "right" way, maintaining the correct wiring orientation from truck to jumper harness, and secure with a zip-tie. The zip tie is required because the H13/9008 male connector does not have a locking tab.
3.) Plug in the truck side reverse light connector.
4.) Run the wiring and LED load resistor down to a suitable metal location, load resistors get hot, and adequate care must be followed when selecting a mounting location. Below is a picture of where I mounted the LED lead resistor on my truck. Note that I used both an aluminum heat sink, secured with 3M VHB 4622 industrial strength adhesive tape. Do not use adhesive tape directly on the resistor. Use industrial grade sticky tape if you mount them as pictured.
5.) Connect the single remaining connector to the 2013+ LED Tail Light, and be sure to slide the red locking tab to the locked position.
6.) Reinstall tail light into vehicle.
7.) Check for proper operation.
8.) Enjoy!
Rep:154
6. OUTPUT COMPARISONS
The first thing that every Ram owner wants to know: Are the 2013+ LED Tails “worth it?” Below are three comparison shots, which should help you decide – but the answer is YES!
1.) Left 2013+ LED Tail Light, Right 2009-2012 Incandescent Tail Light.
2.) Left 2013+ LED Tail Light, Right 2009-2012 Incandescent Tail Light – Parking lights on.
3.) Left 2013+ LED Tail Light, Right 2009-2012 Incandescent Tail Light – Brake lights on.
Rep:154
Post reserved for future information.
Old 02-11-2013, 08:22 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
mine are after market leds and painted and are much brighter then that
Old 02-11-2013, 08:27 PM
NeverEnuff NeverEnuff is offline
Vehicle: 2014 Ram
Rep:87
NeverEnuff will become famous soon enough
Looks great. I love mine. The load resistors I got were 25w 6 ohm so they didn't work even though they are sold exactly for this purpose. They look more neon in person than separate LEDs. I really like them. I don't care for the Larimie version with the chrome trim but some people with chrome on there truck may like them.
Great write up. Looks like you spent a lot of time putting it together. I like how you went the extra mile and used new connectors for direct plug and play. I went the easy way and just spliced the wires direct.
Where did you get your load resistors?
Not trying to hijack your thread but here are a couple pics of mine
Old 02-11-2013, 08:41 PM
Rep:154
Thanks! I love the look of the 2013+ LED's - it's really hard to get a good pic of them illuminated to show the full effect!
I got my load resistors from a seller on ebay named hualiisland.
Nice Ram!
Old 02-11-2013, 08:43 PM
Rep:154
One of the best things about vehicle modifications is that everyone has different tastes!
It's a win-win if you're happy with the LED's you installed and I'm happy with the LED's I installed. What could be better?
Here's to LEDs!
