Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Mopar Online Parts - Dodge Ram Accessories!
Mopar Online Parts - Dodge Ram Accessories! Suppliers of Genuine Dodge/Ram Parts and Accessories at wholesale prices. Shop with confidence as all repair parts orders are checked against the VIN provided to ensure 100% accuracy getting you the right part the first time. All items we sell are backed by a 1yr warranty. - Dodge Ram Accessories!
Old 10-17-2013, 02:55 PM
Pic18 Pic18 is offline
Rep:25
Pic18 is on a distinguished road
It sounds like 2013 harnesses are different than the 09-12 mentioned in the instructions and perhaps the fifth pin needs to be used. If we already have a 2013 truck, is an led tail light not plug and play?
Old 10-17-2013, 03:36 PM
Mopar Online Parts's Avatar
Mopar Online Parts Mopar Online Parts is offline
Mopar Online Parts
Vehicle: RAMz
Trim Level: N/A
Color: N/A
Rep:41
Mopar Online Parts is on a distinguished road
They are not plug and play and I hope no one has misunderstood this.
In order to eliminate the bulb out issue load resistors need to be wired in as well as new harness pigtail as the connectors are different.
-Benny
Old 10-30-2013, 03:28 AM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1475
Originally Posted by emjohn4 View Post
3. ORGANIZE WORKSPACE
Start with a clean work space. Below is the layout of the parts I started with, identified by number below.
4.1 LED TAIL SIDE WIRING
If you sourced the LED pigtail from a junkyard, you will need to move one pin, and remove and discard another, as they are not all in the correct location for the 2013+ LED Tail Lights. Below is a picture of the contact that must be moved and removed and discarded.
To remove a pin:
1.) Remove rear cap with a pick or small flathead:
2.) Remove rubber insert:
3.) Lift up on blue connector retainer with a pick:
4.) Insert small flathead or allen key to release plastic pin retainer.
5.) Remove wire.
6.) Re-insert wire to correct location.
So, if I understand this correctly.. this Step 4.1 is only necessary if you get wiring harnesses from a junkyard?
If I get the wiring harnesses from Mopar Parts Online, this step can be omitted?? The pins will be where they need to be without having to move, remove them on the harnesses from MPO?
Old 03-05-2014, 11:50 PM
jsl6v8 jsl6v8 is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: HFE
Color: Patriot Blue- Merica
jsl6v8 is on a distinguished road
bump for the ^ question, I'm not seeing in these instructions where the 5013984AA Pigtail Harness's are coming in play.
Old 03-06-2014, 12:26 PM
Trim Level: HFE
Ok, ordered all my parts... oh man am I excited and nervous. Let me just say ordering fuel injector connectors to make lights work is odd.
Old 03-06-2014, 03:46 PM
KA1OTE's Avatar
Ram Ham
Rep:1475
After having gathered all parts listed and successfully installing the 13 tails on my 12, I thought I'd report back that the question I posted previously is correct. If you purchase the Mopar harnesses, that step is skipped.
Old 03-09-2014, 12:03 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
^^ is correct - with junkyard harnesses, you'll need to move the pins. If you buy the harness new, you can skip those steps.
Sorry guys - I don't get on this forum much anymore. No time.
Rep:154
Don't be nervous! It works!
Old 04-25-2014, 10:55 PM
jrnannery jrnannery is offline
Vehicle: 2009 Ram QC SLT 4.7L 4x4
jrnannery is on a distinguished road
Does someone have these pigtails pre-assembled, and what kind of cost are we talking about?
Old 04-26-2014, 09:00 PM
Trim Level: HFE
Nope gotta build them yourself, its really not that hard. Cost you're looking at about $70, most everything you can buy off amazon.
