Old 02-12-2013, 09:59 PM
Doc8404's Avatar
Doc8404 Doc8404 is offline
Vehicle: 2008 Dodge Ram 1500 Quad Cab
Doc8404 is on a distinguished road
A little rub isn't too bad, but I'd give it a good look to make sure that there isn't any damage being done..I'd also check the suspension to make sure that it was installed properly and maintained. Good looking truck though.
Yut!
HM(FMF)
Old 02-12-2013, 10:11 PM
dwanton's Avatar
dwanton dwanton is offline
Vehicle: 2015 Ram 1500 ECO Diesel
Trim Level: crew cab SLT
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:80
dwanton will become famous soon enough
the rear tire sure looks like it is not centered in the wheelhouse ?
but I guess it could be the tire size making look that way ?
but that sure sounds like on hell of a deal to me --
whats the carfax look like ?
2015 Ram 3.0 EcoDeisel crew cab -- LEER XQ cap -- Ram Bed Rug -- LED interior lights -- super white 7500k headlamp and fog lamp bulbs -- FoxBox with 2-10" Alpine type R -- Kenwood Amp -- Added factory Reverse Camera --
Old 02-12-2013, 10:13 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Originally Posted by chadster21 View Post
a little rub isnt too bad
Looks like a suspension lift to me. Yes, a little rub isn't too bad...depends on who's doin the rubbin'!
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 02-12-2013, 10:15 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
That is more than likely a 6" lift with a proper offset rim and paired with 12.5" wide tires. If wont rub.
I'd grab it. Find out what the lift is. But I'd grab it depending on price of course
But it does not look like a body lift. But it maybe a body lift and level and yes it will look equivalent to a 6" lift.
So I'd get EM to peak underneath
sales@revelperformance.com
Old 02-13-2013, 07:56 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
im thinkin its a bds 6'' by the way the tires sit in the wheel wells....
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 02-13-2013, 08:42 AM
aedwardzo aedwardzo is offline
Vehicle: 2009 Dodge Ram
Color: Light Graystone
Rep:57
aedwardzo will become famous soon enough
I agree with fast and chadster. It is most likely a 6" lift and no level. You can look under the front of the truck at the axle and the brand should be on the front crossmember
mods..... Too much to list! check my mod list!
http://www.ramforumz.com/member.php?u=58666
Old 02-13-2013, 10:45 AM
Revel Performance
Rep:1804
Or....if its a body lift, it's can only be a 3" (37's won't fit on a 1.25") and you'll be able to see into the engine bay from the front fender liners.
If you can, then it's a body lift. If you can't, pop beneath and peak at the front cross member and the brand will flare right at you.
Either way, not a bad truck to start with
Old 02-13-2013, 06:03 PM
HenrysRam's Avatar
HenrysRam HenrysRam is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: 4x4 Quad cab Express
HenrysRam is on a distinguished road
Looks like a 6 inch lift to me as well.
Have fun in Kyrgztan waiting for your flight home! What branch are you? Were you deployed to Manas or just routed through there since it's a hub?
"It'll stop hurtin' when the pain goes away"
Old 02-17-2013, 11:42 AM
OfcrFr's Avatar
OfcrFr OfcrFr is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Big Horn
Rep:27
OfcrFr is on a distinguished road
Looks like a good truck to me? I would request a close up pic of the suspension to get a better idea. Make it home safe Soldier!
DD and Tow Pig lol-2007 Ram, HEMI, Big Horn, 3.92 gears (open dif) 295/60/20 Nitto Trail Graps, Bilstein 5100s maxed, 18 inch Magnaflow SI/SO with 4 inch tip, Mods added all the time.
Old 02-17-2013, 11:59 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:387
Sweet looking truck
Bilstein 5100's at 2.8. Fox 2.0 rears. MBC Razors with Goodyear Duratracs. Airlift 1000 air bags. Mopar Tow mirrors. K&N air filter. Mopar rock deflector.
