Quick question on running wires - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-12-2013, 03:40 PM
nikeman nikeman is offline
Rep:91
Default Quick question on running wires
I am installing a front camera and I am trying to find an easy acess point that I do Not have to drill into anything to run the wire threw the firewall. I see a few groments with wires going threw already but they are pretty tight. What's the easiest safest place for one thick wire with the video out plug to go threw?
Old 02-12-2013, 04:19 PM
ronnie11223's Avatar
ronnie11223 ronnie11223 is offline
Vehicle: 2011 Dodge Ram sport 1500
Trim Level: sport
ronnie11223 is on a distinguished road
on the main grommet there is a blank tit so to speak you should only have to nip off the tip and you should be able to run your wire threw that I will try to get a pic of it and post it later I used this to feed the wires from my rear cam
Old 02-12-2013, 05:42 PM
Rep:91
I pushed on a small grommet under the big main one and it pushed it pretty easy. I just ran it threw the bottom of that one and it worked perfectly. Put the wire inside right above the gas pedal so I could just go straight under the carpet and to the lockpic
Old 02-12-2013, 10:59 PM
Connman67 Connman67 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman SLT
Color: black/gray
Connman67 is on a distinguished road
Pick a place, there are a few to choose from(Existing holes) There is also a blank plastic plate just below where the steering column that goes through the firewall. You can drill a small hole there, the replacement piece is a couple of bucks if you later change your mind, no biggie. For just a wire, i would just use one that already has crap running through it.
Old 02-12-2013, 11:00 PM
Color: black/gray
Did you buy a lockpic?
Old 02-12-2013, 11:33 PM
Rep:91
I do have a lockpic and now I have a front camera installed! It would have only taken 10 mins if I could get the wire inside from the start. Very easy!
Old 02-12-2013, 11:35 PM
Rep:91
On a side note though. The screen still goes back to the main menu instead of going back to what ever video I was on after the auto function disengages for either front or back camera.
Old 02-14-2013, 06:49 PM
Rep:91
Looks like ill have to call them and see what the deal is.
