Mobile One Oil - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 02-13-2013, 12:11 AM
KYSEAN's Avatar
KYSEAN KYSEAN is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express Crew Cab
Rep:21
KYSEAN is on a distinguished road
Default Mobile One Oil
Can I use Mobile 1 5-30 in my 13? Thanks, Sean
Trailer Hitch, Line-X Spray In bed liner, S&B CAI, Magnaflow 22" and Y-Pipe, ARE Hard Tonneau Cover
Old 02-13-2013, 09:08 AM
Resident Technician
Rep:1915
This is directly from Chryslers service information regarding oil in the Hemi.
For 5.7L engines SAE 5W-20 engine oil is recommended for all operating temperatures. These engine oils improve low temperature starting and vehicle fuel economy. Refer to your engine oil filler cap for the recommended engine oil viscosity for your vehicle. Vehicles with 5.7L engines equipped with Multiple Displacement System (MDS) must use SAE 5W-20 oil. Failure to do so may result in improper operation of the Multiple Displacement System (MDS). Refer to Multi Displacement System under Starting and Operating for details.
Old 02-13-2013, 09:53 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Just a heads up. Mobil 1 5W-20 is presently not Chrysler MS-6395 spec approved
Old 02-13-2013, 10:08 AM
Resident Technician
Rep:1915
That being said, here's Chryslers take on Mobil 1 in the SRT 8. Below that is the double talk that makes this issue so confusing.
NOTE:For 6.1L only Use API rated SL/CF full synthetic engine oil, such as Mobil 1® is recommended. Use the correct SAE grade meeting Chrysler Material Standard MS-10725.
Chrysler only recommend API Certified engine oils that meet the requirements of Material Standard MS-6395. Use Mopar® or an equivalent oil meeting the specification MS-6395.
Old 02-13-2013, 10:09 AM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
But they are testing it, so that's good
http://www.mobiloil.com/USA-English/...r_MS-6395.aspx
Old 02-13-2013, 10:15 AM
Rep:66
Actually, Mobil Super meets the criteria
http://www.mobil.com/USA-English/Lub...bil_Super.aspx
Old 02-13-2013, 10:22 AM
Resident Technician
Rep:1915
If someone brought in a vehicle that had the MS-6395 requirement and there was an engine failure, I guarantee I wouldn't void the warranty for using Mobil 1. Chances are other dealers wouldn't either, mainly because this requirement isn't enforced. As long as you can prove regular oil changes meeting Chryslers service intervals, you should be just fine.
Old 02-13-2013, 10:37 AM
Rep:66
I think you're right!
Old 02-13-2013, 01:14 PM
KYSEAN's Avatar
Rep:21
I will stick with recommended oil vis. but would like to use Synthetic. Thanks for the info, Sean
Old 02-13-2013, 02:10 PM
kong79 kong79 is offline
Color: True Blue
kong79 is on a distinguished road
We had our dealer use Mobil 1 5-20 at the first oil change and they had no problem with it. I've always used Mobil 1 in every vehicle I've owned.
