Old 02-14-2013, 04:43 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Default performace
I want more out of my R/T!!! How many of you are happy with your stock 2600 converter?
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-14-2013, 05:57 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
I've heard that even though it has a factory higher stall that an Edge or Circle-D is a night and day difference... BTW you have a really sharp R/T!!!!!!!!!!
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 02-14-2013, 06:30 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Thanks bro
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-14-2013, 11:07 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
ill change mine out when my warranty runs out
Old 02-14-2013, 11:24 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Im thinking about going with a 3000 or a 3200 but I ant to keep it an everyday driver
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-16-2013, 11:18 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
you know if you change it out youll void your warranty unless the dealer does it
Old 02-16-2013, 05:13 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
ya, guess im going to wait a few more miles.
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-16-2013, 05:39 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
lol drive faster then the miles add up quicker hey you ever call about those tires
Old 02-16-2013, 10:35 PM
I push the skinny pedal
Rep:3277
3000 is about the limit for a daily driver, even then it can be a little high depending on the type of traffic you get into regularly. A higher stall on a DD will cause a lot more heat to be generated in the TC because it's not locked up and working at its peak efficiency. A high stall can also cause a decrease in your MPGs if you have it too high because you'll continually be spinning the TC's impeller faster than the turbine, wasting engine power to fluid losses and heat instead of spinning the turbine side.
Now, if you plan to do more track time or spend time at or above 3000 rpm, then I'd say go for it, otherwise it might be better to stay with the 2400 or go as high as 2800 for a DD.
If you care to do some reading, Banks has a great article on TCs.
http://www.bankspower.com/techarticl...que-Converters
Kurtis
Old 02-16-2013, 11:11 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Thanks for the read
SPONSORED BY
BULLY'S PERFORMANCE
