Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 02-11-2013, 12:48 PM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew
Color: PX8- Black Clear Coat
Rep:31
11HEM1 is on a distinguished road
Default Removed Fender Flares Need Help with Scratches
Took off the fender flares now I have scratches on the paint need suggestion to get them off tried scratch x with no luck they are not deep enough to catch a finger nail on
Debadged -4" Mopar Lift - XD Cranks - 325/60/20 Nitto Grapplers
Old 02-11-2013, 05:21 PM
travis55's Avatar
travis55 travis55 is offline
Vehicle: 2012 Dodge Ram 1500 Sport
Color: Mineral Gray Metallic
travis55 is on a distinguished road
you might have to take it to a body shop if they are that deep or try wet sanding
Old 02-11-2013, 06:24 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:207
bstc00 has a spectacular aura aboutbstc00 has a spectacular aura aboutbstc00 has a spectacular aura about
Do you still have the flares? You want to sell them? Pm me.
Old 02-11-2013, 08:35 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
did you use the scratch x by hand?
its hard to say without seeing a picture if the scratches will come out, but you should be able to get them if you dont feel them on your fingernail.
If you have access to a machine polisher, the scratch x should work, but there are definitely more aggressive products out there...
if you can, post up a pic...
Old 02-11-2013, 09:17 PM
11HEM1's Avatar
Rep:31
Yeah I just tried the scratch-x by hand I was thinking maybe I can get a polisher or a get it professionally done
Old 02-11-2013, 09:25 PM
Grubrunner's Avatar
Rep:3883
A professional car detailer will charge you a good penny.
It's really very easy removing fine surface scratches and the like....with the right tools and armed with the proper method.
I've had a lot of luck removing fine swirls and minor scrathes using the method and products below.
HERE is the instructional video.
Grub out!
Old 02-11-2013, 09:43 PM
dwanton's Avatar
dwanton dwanton is offline
Vehicle: 2015 Ram 1500 ECO Diesel
Trim Level: crew cab SLT
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:80
dwanton will become famous soon enough
1200 wet sand paper making small swirls over the area , then go over with 1500 wet sand paper if you want but dont have to ,then hit it with a buffer and some compound , then some polish .
they cant possibly be that bad , so they should come right out pretty easily .
dont do this if you dont know what you are doing as for you might sand through or buff through your clearcoat ..
any reason why you removed the flares ? i'd be interested in them .
2015 Ram 3.0 EcoDeisel crew cab -- LEER XQ cap -- Ram Bed Rug -- LED interior lights -- super white 7500k headlamp and fog lamp bulbs -- FoxBox with 2-10" Alpine type R -- Kenwood Amp -- Added factory Reverse Camera --
Old 02-13-2013, 01:05 AM
cj1's Avatar
cj1 cj1 is offline
Vehicle: 2010 Dodge Ram1500, 2004 600RR
Trim Level: SLT Sport
cj1 is on a distinguished road
Im in the same position, looking to ditch my bushwacker pocket style flares. The scratches are deep, i had a detailer say it can be done with a fair bit of work.
Old 02-15-2013, 01:23 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Trim Level: Express RC
Color: Black Express Package
Rep:67
I would use a 2000 grit wet paper but you need a buffer to polish it out and if you aren't careful you can burn through the stock clear pretty easy. Go by a local dealer and look for there detail shop out back and those guys will usually do it pretty cheap. Try a high end store 1st the better the cars the better the detail guys at least in Houston. They may have people like me who recon used cars on site. I have had a few people come up to me with minor stuff while working in the back of the dealerships. I usually charge between $20 and $50 got sanding and buffing panels depending on how much damage is there. For a truck like yours most people like me do it on the side would charge you between $20 and $40 to do the wheel wells.
