Old 02-14-2013, 06:56 PM
Alberto22's Avatar
Alberto22 Alberto22 is offline
Vehicle: 2011 ram 1500 quad cab
Color: Deep water blue Pearl
Rep:72
Alberto22 will become famous soon enough
Default issues with alignment
I have a 2011 ram 1500 with 26000 miles on it and just had it leveled with Bilstein 5100. The truck rides fine but wont track straight. The shop that did the job did an alignment afterwards and it tracks to the right, The shop apologize and said there machine might be off and might need to be re calibrated and to take it some where else and they would pay for it to be done. So I went to Firestone and they said they wont do the job cause they will set it to factory specs and it will still be off. They also told me they will not do any truck that has been lifted or lower for the same reason. So i want to Mavis and they tried to do the alignment. After two tries same results the truck still tracks to the right. Mavis also swapped tires left to right to see if a tire shifted a belt causing this to happen no luck. Mavis said all specs are where there supposed to be and has no clue why truck tracks to the right..... I NEED HELP!
The best way to a fisherman's heart is through his fly!
MODS. f1 bakflip, rain guards, Mopar bug deflector, husky floor liners, chrome gas cover, westin side steps,steal craft brush guard,Piaa fog lights, painted calipers, sport hood, KENWOOD EXCELON DNX9980HD with cmos 300 camera, Magnaflow 14"
Old 02-14-2013, 07:46 PM
twenty12ram1500's Avatar
twenty12ram1500 twenty12ram1500 is offline
Vehicle: 2012 ram 1500
twenty12ram1500 is on a distinguished road
Hey hows it going... im from longisland also and i have a 2012 1500 crew cab with a 6" RCX lift and 5100's installed and had it done by Good Year in commack they are awesome and my truck has never tracked straighter .... i would try them ... they have brand new top of the line machines and are open 7 days a week .... any thing else i can help with PM or In box Me
Old 02-14-2013, 08:21 PM
Alberto22's Avatar
Rep:72
I just might make the trip out there just so its done right! is that the Goodyear on Jericho? there are 2 one on the corner of Jericho and commack rd (6400 Jericho) or the other 2205 Jericho turnpike. Thanks I REALLY appreciate the help!!!! Did goodyear do the lift and the shocks for you too?
Old 02-14-2013, 10:10 PM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
Some business's just dont need your money I guess, how are your tires pressures?
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 02-14-2013, 10:19 PM
Alberto22's Avatar
Rep:72
one of the rears was off by ten psi (higher) which i told the fist shop and they set them all the same. Looking to get this problem fixed before my terra grapplers come in.
Old 02-15-2013, 04:31 PM
Alberto22's Avatar
Rep:72
Turns out I needed a place that knew what they were doing. All is well with my ram now thanks to TWENTY12RAM1500 !!!!
Old 02-15-2013, 07:03 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
It took Firestone 3 tries to get mine aligned. I got their "Lifetime ALignment " when I bought new tires and the first time I drove it it pulled BAD to the right. So a couple weeks later I brought it back in and asked them to check it. When it was done I asked if it was out. They said " oh yeah the toe in was way out!" I said "how can that be when YOU guys aligned it 2 week ago?" They responded with," Uh, well it's fixed now."
Old 02-15-2013, 07:05 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
i used to work at firestone for a month lol that was a month to long they are crooks and half the time they dont even align you shit they hit the sensors till machine goes green
Old 02-15-2013, 09:01 PM
09nitetrain 09nitetrain is offline
Vehicle: 2006 raqm 1500 trx4 hemi
Trim Level: trx4
Color: blue
Rep:20
09nitetrain is on a distinguished road
i did my own alignment after i leveled mine at the shop. put it all with in spec. and mine goes straight steering wheel straight. no issue. it just takes a little time and people being on flat rate wont take the time to make it perfect. its usually set the toe and let it go. you got to do caster and camber and keep doing caster swings after you make an adjustment and set toe last.
