Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 02-13-2013, 03:03 PM
KTMANN KTMANN is offline
Vehicle: 2008 Ram 1500
Trim Level: Lariat
KTMANN is on a distinguished road
Default Stuck in Park
Hello I searched this and it gave me answers on 2010 not 08's .
Shifter gets stuck in park at times, from doing research it looks like BTSI, brake lights work ok so I ruled out the brake switch.
The issue is I called the dealer and they told me my truck just has a cable and not a BTSI.. I gave him the VIN and this is the answer he gave me . I think I just spoke with a dink.
I really called for a price on the BTSI but according dealer dink my truck doesn't have one.. I'm sure it does.
So for those of you who have replaced this piece how much was it and is it difficult to change. Thanks.
Old 02-13-2013, 08:19 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Rep:26
06PowerWagon is on a distinguished road
The BTSI (Brake Transmission Shift Interlock) mechanism is on the shift cable were to attaches to the column shift lever. It is working. It will not release when the brake pedal is depressed. It only releases if I unplug it. With a small child it is a safety feature I can't do without. ...
Is it a Column shifter or floor...
Smile even if its a little creepy
Old 02-14-2013, 11:09 AM
Trim Level: Lariat
It's a column shifter, so if I unplug it will work but it will be unsafe because it can be pulled out of park with out depressing the brake pedal?
If unpluged does it effect anything else such as factorey remote start or cruise? Thank you for your help.
Old 02-14-2013, 11:37 AM
Rep:26
TO be safe contact the dealership and tell them.. But most adults push the brake down the put the truck in gears.. its a safety feature... so IF you unplug it you can easily place the truck into gears without the brake being applied... But to be safe tell your dealer
Old 02-14-2013, 01:49 PM
Trim Level: Lariat
Thank you or your help.
Old 02-14-2013, 06:47 PM
Rep:26
No probably and keep me posted on how it works out for you
Old 02-15-2013, 11:59 AM
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
Actually I believe the BTSI is set up so it must be powered to pull out of Park. If you simply disconnect it, it will be LOCKED, not unlocked.
