PCV valve - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-15-2013, 11:00 AM
06RAMbo's Avatar
06RAMbo 06RAMbo is offline
Vehicle: 2006 Dodge Ram
Trim Level: 1500 SLT
Color: Royal Blue/Grey
06RAMbo is on a distinguished road
Default PCV valve
Goodmorning Forum crew!
I am replacing my PCV valve today...the problem is locating that beast! LOL! I have the "Haynes" manuel and also seen all the typical diagrams that show the neck of the oil tube...except on my Ram...it's NOT on the oil filler tube. I am baffled till I read a bog a guy wrote on a website where the guy said follow the 1/4 inch tube that is attached to the factory airbox. Well I have one and it goes toward the back of the engine (toward the passenger firewall) and elbows down onto the back of the motor next to the transmission dip stick. Is this the were the PCV valve is located? is this normal for a 2006 Ram 4x4 4.7L??? EVERYTHING I have read said it is attached to the oil filler tube. What's up with this and is it easy to replace? do you just wedge it out or do you have to turn it counter clockwise like on the tube? Thanks so much!!!
My wife Loves my RAM
Old 02-15-2013, 11:03 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I know the 2007 rams have a internal PCV system. I'm assuming that means it's not accessible? It's probably the same for your 2006. Hopefully someone who is more certain will answer you. I know when I was inquiring about a catch can, i was told they can't be used on our trucks because the PCV system is internal
Old 02-15-2013, 11:13 AM
Resident Technician
Rep:1915
25 - Emissions Control/Evaporative Emissions, Except Diesel/VALVE, Positive Crankcase Ventilation (PCV), 4.7L and 5.7L/Removal
REMOVAL
Labor Operations: Click to display a list of Labor Operations associated with this procedure
The PCV valve (4) is mounted into the top of the intake manifold (1). This is located to the right / rear of the throttle body (2).
1.The PCV valve is sealed to the intake manifold with 2 O-rings (2).2.Remove PCV valve by rotating counter-clockwise 90 degrees until locating tabs (3) have been freed. After tabs have cleared, pull valve straight up from intake manifold.3.After valve is removed, check condition of 2 valve O-rings (2).
Old 02-15-2013, 11:14 AM
Rep:1900
o i also didn't notice he had a 4.7. But thanks ramtech! Trust him way more than me!
Old 02-15-2013, 11:35 AM
06RAMbo's Avatar
Thanks for the replys! If RamTech wouldn't have posted this...I would have never known! Thanks for the diagrams!
@Gonefishin...thanks! Any and all info helps. I had no idea about an internal PCV valve.
Still learning something new everyday. I have always either owned Ford or GM....LOVE MY RAM!
Old 02-15-2013, 06:37 PM
06RAMbo's Avatar
REMOVAL
I found the PCV valve today, but it was out of my reach for the time that I had. Staring at the engine from the front it is located at the very back of the engine toward the driver side firewall. This is very odd to me since pretty much noone has any info of it being there.
Old 04-22-2013, 12:11 AM
Twinkeys0816's Avatar
Twinkeys0816 Twinkeys0816 is offline
Vehicle: 2006 Dodge Ram 1500
Twinkeys0816 is on a distinguished road
i figured its already too late for this but ill just put it in anyways. your going to need a 34mm deep socket for the pcv valve which is treaded to the valve cover very easy to take out did mine in 5 mins. the old one was very dirty and covered in mud. oh and i got my pcv valve from rockauto since all the local parts stores couldnt find me the right one. the one i got from rockauto was exactly the same pcv that i replaced.
Old 02-24-2015, 04:05 PM
Gniccum Gniccum is offline
Vehicle: 2010 Dodge Ram 1500 HEMI 4x4
Color: Metallic silver
Rep:21
Gniccum is on a distinguished road
This may be a little late. But I replaced the PCV valve on my 07 4.7l ram. It's behind the drivers side valve cover, right next to the firewall. It will have a hose connected to it, pop that hose off and the valve comes off with a 35mm deep socket. Pain in the a** to remove if your hands are big.
