Place your Ad Here!
Old 02-15-2013, 02:51 PM
FF12's Avatar
FF12 FF12 is offline
Vehicle: 2012 Dodge Ram 1500
Color: Mineral gray
FF12 is on a distinguished road
Default SRT 10 Wheels and Rubbing Issues
I have been reading alot of talk about the SRT 10 Wheels (22x10) and them fitting for some people but rubbing for others. Just trying to get a straight answer before I pull the trigger. Tire size I am looking at is the 305/45R22, going with the 45 series because I will only be doing the 2 inch rear GF drop. So the question is will they rub or not? If they do rub what size spacers will I need? My truck is a 2012 Express Quad Cab 1500 Hemi 2wd.
CST 7 inch lift, Bilstein 5100 Front & Rear, 22x11 Fuel Krank, Durun Terrain Grabber M/T 325/50r22
Old 02-15-2013, 03:32 PM
Kcbigbadram's Avatar
Vehicle: 2007 1500
Trim Level: Big horn
Color: Inferno red
Rep:503
mine rub with that size tire. 1/4 spacer fixed it but when i get new tires i think im going to go with 285/45
Old 02-15-2013, 04:08 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
Mine rub at full lock, but it doesn't bother me and you really shouldn't turn that far anyway, not good on the steering system.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 02-15-2013, 04:49 PM
figs45 figs45 is offline
Vehicle: 2014 Ram 1500 Sport Crew
Color: Max Steel
figs45 is on a distinguished road
I'm putting RT 22" wheels on my 2012 1500 Sport and am going with 305/45/22 tire size also. I checked manufacturers section widths of all available 305's and found that a lot of 305 tires have a section width of 11.9-12 inches. Yokohama Parada SpecX in 305/45/22 have a section width of 11.5 inches so that might reduce rubbing and also the need for spacers while still keeping over all height the same as factory 20"s. I also agree that turning full lock is unnecessary so I won't be needing spacers.
Old 02-15-2013, 04:51 PM
Vehicle: 2007 1500
Color: Inferno red
Rep:503
do you have replicas? mine rub just sitting there with wheels straight on.
Old 02-16-2013, 05:42 PM
FF12's Avatar
Color: Mineral gray
Are the Yokohama Prada SpecX a directional tire?
Old 02-16-2013, 05:49 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
get the nitto tires have them on mine 305/45/22 kmc slide rims and i have 0 rubbing not sure if the rim makes a difference as far as rubbing you can also get a 22x9.5 rim instead if you put spacers on it they will stick out if not mistaken
Old 02-19-2013, 12:13 AM
RAM EM's Avatar
Color: Grey
Rep:195
Yep, they're replicas.
You probably have a little less offset on the Slides.
Old 02-21-2013, 12:04 AM
Vehicle: 2007 1500
Color: Inferno red
Rep:503
I wonder if replicas have a different offset than oem
Old 02-21-2013, 03:44 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Biggest issue is the difference in tire sizes between brands. One brand's 305/45 may be an inch wider or narrower than another brand's 305/45. Plus tire companies grind tires down slightly on the tread shoulders to help with roadforce issues.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
