Old 01-04-2013, 09:45 AM
farmall farmall is offline
Vehicle: 2003 3500 QC diesel
Color: Patriot blue
farmall is on a distinguished road
Default need injectors for my 2003 5.9
My mechanic seems to think I need injectors (after the new lift pump and injector pump). Does anyone have any suggestions on what brand, etc to get. Would this be a good time to get an aftermarket one that might be cheaper or better? Does anyone have some new take offs that they would want to sell?
Old 01-04-2013, 11:25 PM
deke rivers deke rivers is offline
Vehicle: 2004 dodge ram diesel
Trim Level: deluxe
Color: gray
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
deke rivers is on a distinguished road
make sure you really need them cause they will cost you a bundle..i was told that my 04 2500 with 130k miles needed injectors..price each at dealer was 895.00 my truck had lost power and would barely go at all...turned out it was my power module. unplugged it and now truck runs like a rabbit...
Old 01-06-2013, 09:54 PM
skinnysfd's Avatar
skinnysfd skinnysfd is offline
Vehicle: 2012 dodge ram 2500
Trim Level: big horn
Rep:53
skinnysfd will become famous soon enough
895!!!! holy !#$% thats expensive. Ive always went through diesel specialties and got mine and it was 1800 for all 6 on my 03 . About 2 hrs later they were all installed. Install is simple and u can do it yourself. But check the wiring harness under your valve cover first cause it has been know to get pinched and cause a faulty injector reading. It runs through the gasket actually i believe its part of the gasket. Also when i bought mine on my 03,04.5,and my 06 i just had diesel specialties test em too and they give ya a break on price if ya have them test em. Hope it helps and i wouldnt just replace 1 or 2 do em all that way you dont have problems down the road. I always use bosch injectors as well. And when you do it make sure you get the fuel rods as well dont reuse the old ones.Also i just sold my spare set i had to a guy so cant help ya there.
2012 RAM 2500 HEMI AFE CAI flowmaster dual exhaust,airlift 5000 bags w/onboard compressor,shaved tailgate,2.5" lift/level tuftruck front springs,bushwacker pocket flares,gear alloy wheels, goodyear duratracs 315/70/17,bd gt hemiplus tuner much more coming
04.5,2006 5.9l cummins
Old 01-08-2013, 12:41 PM
dodge man's Avatar
dodge man dodge man is offline
Vehicle: 2004 Quad Cab diesel
Rep:221
dodge man has a spectacular aura aboutdodge man has a spectacular aura aboutdodge man has a spectacular aura about
I've read that Exergy makes good injectors, and yeah, they aren't cheap.
2004 3/4 ton Quad Cab, 24 valve 5.9 Cummins
Old 01-09-2013, 04:23 PM
CalicoJack CalicoJack is offline
Vehicle: 2003 Quad Cab Cummins
CalicoJack is on a distinguished road
I put the stockers in mine when I needed them. Spoke to a cummins specialist and he recommended the stockers so that is how I went. He also said to change out the tubes that supply the injectors.
Good luck
Old 02-01-2013, 06:42 AM
Color: Patriot blue
Thanks guys. I did replace all of them. That seemed to be my problem. I had to replace the lift pump, injection pump and injectors and tubes. I thought I was going to have to get a loan to get it out of the shop. Then, I had to go buy tires. I went to get an alignment yesterday and I need about 6 suspension parts replaced. I am probably going to be over $6000 in the last 3 weeks.
Old 02-01-2013, 03:25 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Rep:365
There are updated tie rod and lower ball joints for your vehicle. They are much stronger and wiill probably last longer than the old style. Make sure you check with the dealer. I replaced mine on my 04 1/2 and was a lot more satisfied with the size and strength of the new updated parts. Sorry, I don't have the part numbers any longer.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected.
Semper Fi Forever
Old 02-02-2013, 11:15 AM
skinnysfd's Avatar
Rep:53
i always replace my front end with moog parts. very heavy duty and alot cheaper than what the dealer charges and much better quality
