Old 02-16-2013, 07:45 PM
Hkdevious88's Avatar
Hkdevious88 Hkdevious88 is offline
Vehicle: 2009 dodge ram 1500 hemi sport
Trim Level: sport
Hkdevious88 is on a distinguished road
Exclamation 09 ram leveling kit
I had a rough country 2.5 leveling kit and 2"body lift on my truck, and had new cooper zeon Ltz tires put on and drove it for like 30 k miles with everything aligned. Then noticed chopping wear on my tires, had the alignment fixed again and they said it was just a little bit out. I'm buying new tires and don't want the wear like this again? Was it the alignment a little out? Or is it my leveling kit throwing them out? Please help!?
You ain't Rollin until your Trollin
Old 02-17-2013, 09:20 PM
I push the skinny pedal
Rep:3277
Most likely culprit is your lift causing the issue, was it aligned after the lift? If not, the new alignment should make a difference, also, with that much lift/level you should rotate and balance more often for the first year to see if how everything works together.
Kurtis
