Old 02-16-2013, 09:15 PM
lastainlesssteel's Avatar
lastainlesssteel lastainlesssteel is offline
Vehicle: 2003 Dodge Ram QC HEMI
Trim Level: Slt
lastainlesssteel is on a distinguished road
Default hemi performance parts
5.7 Hemi Performance parts
TCI torque converter, Comp cam, Comp valve springs
Make DODGE Transmission Type 45RFE Torque Converter Usage Street/Strip Advertised Flash Stall Rating (rpm) 2,400 rpm
TCI Auto 141600 - TCI Breakaway Torque Converters
Torque Converter, Breakaway, Chrysler, Dodge, 5-45RFE, Hemi,
Part Number: TCI-141600 Each $396.95
These TCI Breakaway torque converters will give you about 1,000 more rpm stall speed than stock, so you'll launch and accelerate faster. TCI remanufactures them to last with furnace-brazed fins, needle bearings, and a flame-hardened hub--the same qualities that they gave their street/strip converter.
Brand TCI Auto Manufacturer's Part Number 141600 Part Type Torque Converters Product Line TCI Breakaway Torque Converters
Summit Racing Part Number TCI-141600 UPC 788120036757
Anti-Ballooning Plate No
Lockup Yes Furnace-Brazed Yes
Balanced Yes
Hardware Included No
Notes 2003 and later Hemi.
COMP Cams 112-502-11 - COMP Cams Xtreme Fuel Injected Camshafts
Camshaft, Hydraulic Roller Tappet, Advertised Duration 273/277, Lift .547/.550, Mopar, 5.7/6.1L, Hemi, Each
Part Number: CCA-112-502-11 $398.95
Brand COMP Cams Manufacturer's Part Number 112-502-11 Part Type Camshafts Product Line COMP Cams Xtreme Fuel Injected Camshafts Summit Racing Part Number CCA-112-502-11 UPC 36584115601
Cam Style Hydraulic roller tappet Basic Operating RPM Range 2,000-6,200
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 228
Duration at 050 inch Lift 224 int./228 exh.
Advertised Intake Duration 273
Advertised Exhaust Duration 277
Advertised Duration 273 int./277 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.547 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.550 in.
Valve Lift with Factory Rocker Arm Ratio 0.547 int./0.550 exh.
Lobe Separation (degrees) 114
Computer-Controlled Compatible Yes
Grind Number 273H-11
Valve Springs Required Yes . Notes Fits engines without variable cam timing. A programmer upgrade is required for this camshaft.
COMP Cams 26918-16 - COMP Cams Valve Springs
Valve Spring, Single, Beehive, 1.075 in. Outside Diameter, 372 lbs./in. Rate, 1.100 in. Coil Bind, Set of 16
Part Number: CCA-26918-16 $187.95
Brand COMP Cams
Manufacturer's Part Number 26918-16
Part Type Valve Springs
Product Line COMP Cams Valve Springs
Summit Racing Part Number CCA-26918-16
UPC 36584077473
Number of Springs Per Valve Single
Outside Diameter of Outer Spring (in) 1.075 in.
Coil Bind Height (in) 1.100 in.
Damper Spring Included No
Spring Rate (lbs/in) 372 lbs./in.
Inside Diameter of Outer Spring (in) 0.650 in.
Valve Spring Style Beehive
Coated No
Quantity Sold as a set of 16.
Notes O.D. at the top of the spring is 1.075 in. and 1.310 in. at the bottom. I.D. at the top of the spring is 0.650 in. and 0.885 in. at the bottom
all this for $500
and how good is this setup if installed and what else would i need
Old 02-16-2013, 09:26 PM
Trim Level: Slt
so the guy is selling this all for $500 and i want to get it but i dont know what else i would have to do to my truck in order to install these parts and if its worth it everything is brand new
Old 02-16-2013, 10:16 PM
I push the skinny pedal
Rep:3277
A 2400 still is not much of a step up from the factory stall, so it really won't make a big difference. The 273 Comp Cams is a high rpm cam, you'll lose quite a bit of your bottom end, which is where you need to keep it to move the weight of these trucks.
Looking at the setup, I'd recommend passing on it unless you plan to do ported heads, and run a power adder like nitrous or a s/c where you can take advantage of the higher rpm band more often.
Kurtis
Old 02-16-2013, 10:35 PM
Trim Level: Slt
Default 0k
ok thanks for the info i just thought it was a good deal thats why i posted to see what you guys think, very helpfull i was planning on doing that and just putting 4.55 gears but ill just pass on it then. so what setup should i get i drive all over the place alot of highway driving but i dont care for top speed i just want a good 1/4 mile truck. that i can still drive across the country if i need to but yeah i have no plans on putting a s/c or nitrious
Old 02-16-2013, 10:46 PM
Rep:3277
If you want a good all-round cam with good torque and modest fuel economy then look at the comp XFI260 or for a bit more midrange the XFI268 would be the limit to my recommendations. The 260 will get you moving the best as it's bringing on power in the 1000rpm range where as the 268 you're looking at 1500rpm.
With either of those cams you can still use stock push rods and springs, but I would recommend upgrading to a set of 6.1L springs to add reliability to the valve train.
While you have the timing cover off, you could upgrade to a 20% underdrive pulley to reduce some of the parasitic losses.
Kurtis
Old 02-19-2013, 07:18 AM
compressor man's Avatar
compressor man compressor man is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Sport
Color: silver
compressor man is on a distinguished road
That set up is not matched up at all, a 273 cam isn't ideal for a QC and it would need a 3400 stall at least. Pass on that for sure. I run a Sidewinder and a CircleD 2800 stall, it is a great all around cam, tons of torque and power all the way to redline. It is very similar to the 260. I would strongly recomend the 6.1L springs and pushrods, along with a custom Diablo tune.
FRI'D 2007 RAM SLT SPORT 4x4 in the 13's
