Old 02-21-2013, 01:00 AM
RDB RDB is offline
Vehicle: 2011 dodge 2500
Trim Level: laramie
Color: black/tan
RDB is on a distinguished road
Default 11 2500 hemi with 35's need to see better mpg??help
so i bought this 2011 2500 hemi thinking it would atleast pull 15mpg running mostly highway..no the best ive seen is 12.2 but average has been 10.7mpg and i haven't got on it. the truck has 22,000miles and his a caril leveling kit with dick cepek mud country's,stock rims... i need some effective suggestions on what others are doing to see better mpgs out of the 2500 hemi's,and its not the power-wagon..any help would be appreciated
Old 02-21-2013, 02:37 AM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
I have a 1500 hemi, and I'm worst than you with 35s., I ilde ton though and mostly do city driving. Best bet is gears.
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 02-21-2013, 05:37 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I run 35 m/ts and average around 13/14.
get a tuner is my suggestion
Old 02-21-2013, 07:35 AM
DEEPFADE's Avatar
DEEPFADE DEEPFADE is offline
Vehicle: 2011 Dodge Ram
Rep:24
DEEPFADE is on a distinguished road
I have a 1500 and as of last weekend I pulled off the 35's and went with a 33 Nitto Crosstek. Their 20lbs. lighter per tire!!! So far I'm seeing great results.
/Volumes/USB20FD/2011-02-189515-48-4695367.jpg
Old 02-21-2013, 08:16 AM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
I don't think you are alone with your mileage. I looked at 2500's and most people where struggling with mileage with the Gas engine. It's just such a heavy truck, add on bigger tires and I'm not surprised with your mileage. The Chevy's and Ford Gas engines are getting the same mileage too btw.
Gears and tuner would probably be the best way to "try" to improve mileage. Also, if you didn't recalibrate you speedo/odo you will be showing worse mileage than you are really getting.
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 02-21-2013, 09:56 AM
svt2026 svt2026 is offline
Vehicle: 2011 Dodge Ram 2500
svt2026 is on a distinguished road
Forget the tuner it got me no gain in mpg. I have a 2011 2500 so im seeing 9-11mpg mostly city. I have the 3:73 gear and the Power Wagon i think has 4:56. There is nothing really you can do except live with it or trade it in on a diesel or lighter truck. Don't buy in to the notion that the intake or exhaust will get any mpg or even noticeable hp gains. BTW power wagon rocks.
Old 02-21-2013, 11:43 AM
Color: green
Rep:657
going to a lighter street tread tire will give a bit of an improvement.
Old 02-22-2013, 05:14 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
Is your speedo correct? If they installed your 35" tires and didn't adjust the computer, the figures will read low. I seriously doubt you can do anything though to get the MPGs to 15 with that size of tire.
I get about 14 mpgs with 4.10s, 33" tires, and the new 6 speed in my 2012 2500 Hemi. That is a mix of city, highway, hills.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 02-22-2013, 06:10 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
RDB, man that's a tall order to ask from a near 8000 lb 3/4 ton 4x4. The problem with modifying is sometimes vehicle handling and aerodynamics get thrown outta whack. If you want to continue running 35's then gearing and speedo calibration is a must. But here's the bad news, the tires are heavy and your truck sits higher and those mudders or all terrains arent helping in the aero department. It's just the nature of the beast. It's not the Hemi's fault for low highway fuel economy. You just have to find the right combination of add ons to get it all to work like it was engineered from the get go. Your 3.73's are your number first fix to address if your going to stick with 35's. 4.10s I think would get you moving towards the right direction. And don't forget to have your ECU flashed to tie it all together. Or invest in a programmer.
Old 02-24-2013, 08:12 AM
crazyjj crazyjj is offline
Vehicle: 2011 Ram 2500
crazyjj is on a distinguished road
I run 37's on my 2011 2500. With all my mods I see 14-15 on the freeway.(65-70 miles per hour) In town I get 8-9 mpg. The only way you see better MPG is changing the gears. Lift with Hemi=bad gas mileage.
Best of luck to you.
Jake
