Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 02-17-2013, 09:17 PM
Bluebee Bluebee is offline
Bluebee is on a distinguished road
Default TLC got her done
So I bought this system awhile back but haven't had time to install it. Two weeks ago I went ahead and finally put it in. Unfortunately the brass fittings with the plastic hose adapters that go into the bags were defective and leaked. I emailed customer support and found out about the new top mounts, so I went ahead and ordered them w/new fittings. I will say that it was quick to install, initial install less than two hours and about another hour to install the top mounts. The drive/feel of the top mount installation is awesome, truck feels sportier and handles great, plus my air leak issues are all resolved. I did opt for a simple install, one power line from battery to the case under the rear passenger seat, all neatly tucked a way for no fuss. Really appreciate your customer service. As others have noted the bags do rub w/the bottom install, but a bit more so w/the top mount. However as stated they move in unison to the coil, also oddly enough the biggest contact is now on the passenger side coil and not the driverside, will keep an eye on it and report back...
Old 04-10-2013, 11:17 PM
Well took the truck, attached my 24 foot long enclosed car trailer, loaded up a dodge charger race car and took 1600 mile trip. The whole system worked great, trailer was stable and it was a really good ride.
