Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 02-18-2013, 12:01 PM
kegoramma kegoramma is offline
Vehicle: 2002 Dodge RAM 1500
Trim Level: SLT Quad Cab
Color: Gold
kegoramma is on a distinguished road
Default 2002 Ram 1500 autotrans will not shift!
The automatic transmission on my 02 ram 1500 will not shift out of 1st gear. It has enough fluid, just will not shift. I tried turning it off and on, poping it into nutral, and truning the overdrive on and off. None of these simple steps helped. What could be wrong with it. I would take it to a shop but I'm not made out of money ;-) any help is appreciated!
Old 03-02-2013, 02:22 PM
SmittyOwnz's Avatar
SmittyOwnz SmittyOwnz is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: SLT 4X4
Color: FLAME RED
SmittyOwnz is on a distinguished road
yeah this has happened to me too.
2002 DODGE RAM 1500 4X4 SLT
Old 03-02-2013, 02:27 PM
SmittyOwnz's Avatar
Trim Level: SLT 4X4
Color: FLAME RED
Also what codes from your check engine light are you receiving?
check this out too!
http://www.justanswer.com/dodge/2g4o...-shifting.html
Old 06-14-2013, 02:52 AM
Dustin02Ram's Avatar
Dustin02Ram Dustin02Ram is offline
Dustin02Ram is on a distinguished road
What did yall figure out? just got my truck a month ago and it sticks in first sometimes and wont shift. Will I need to rebuild it? Cant afford to take it to a shop or 1250. for a rebuilt one.
If you aint first you're last...
Old 06-14-2013, 05:34 AM
Nemmisis1 Nemmisis1 is offline
Vehicle: 2013 Ram 1500 sport
Color: BLACK
Rep:51
Nemmisis1 will become famous soon enough
Change the filter and fluid in the trans...might have dirty oil and its not flowing trought the veins in the trans. Take it to jiffy lube or something 100 mucks worth a shot .. Maybe less
Old 06-16-2013, 12:48 AM
775carguy 775carguy is offline
Color: Charcoal
775carguy is on a distinguished road
I agree with the trans service. I would NOT however take it to jiffy lube. They will pump it out not change the filter. The kit is about 15 bucks at Oriellys and The fluid is cheap enough. My 02 1500 did the same thing. I changed the fluid(yes it can be messy). But its worth saving the couple hundred or more to let some one else do it. Unbolt the pan a little at a time. Slowly dropping the pan dont try to do it all at once it will go every place. When you get it down the filter has 2 bolts holding it up remove them. Put the new one on. Note the pan gasket is reusable. Pretty nice. I actually put a 6$ drain plug in mine to make it easier for ther next service. I think i spent 90 bucks or so for everything and it took about an hour. Shifts great. So i saved cash and got to do it myself.
