Old 02-18-2013, 05:57 PM
Ted98 Ted98 is offline
Vehicle: 1998 Dodge Ram Magnum
Ted98 is on a distinguished road
Default Bad Cat or running lean?
Just a few days ago I noticed a propane smell when I came to a stop. Its not all the time but I smell it about 2-3 times a day. At first I thought there was a diesel pickup near by running propane injection but it has become to frequent to be that.
I have been told it's my cat going bad but I always thought that a bad cat smelled worse then that and more like a sulfur/skunky smell.
Someone also mentioned to me today that it sounds like I could be running lean.
Without an AFR gauge on my truck or access to a decent scanner (all I have is for heavy trucks and a code scanner). I can't see in I am in fact running lean.
Any thoughts on what could be wrong?
Old 02-18-2013, 09:46 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Do you buy gas from a certain gas station? It is possible you are just pumping a bad batch! Other than that if you have a 1996 or newer there will be a post-cat oxygen sensor which should set off a emissions failure code, if you are getting this code than it is either the cat or the sensors.
Old 02-19-2013, 12:53 PM
I get gas from several different places. And I have scanned my truck with the code reader. No codes come up. I have a super advanced scanner but I am a heavy truck mechanic and the scanner doesn't work on OBDII.
Old 02-19-2013, 01:13 PM
Rep:2657
I believe on the older CATs,
The tile coating of Platinum & Palladium starts to break down after a period of use
When it breaks down, it is said to smell like burnt almonds or rotten eggs
When it does break down, you could give the side of the Cat a rap or 2 with the palm of your hand & hear it moving.
From what i understand, the newer Cats use a different way of applying the precious metals & the old way of hitting it does not work
