Old 02-18-2013, 06:16 PM
devout3ebfan's Avatar
devout3ebfan devout3ebfan is offline
Vehicle: 2005 Dodge Ram
Trim Level: 1500 Laramie
devout3ebfan is on a distinguished road
Smile Future Plans with the Truck
Hello,
I need your guys' input because I am not as familiar with aftermarket parts as you are. I am looking to get a new set of wheels and tires. I would like to get 17" fuel off-road wheels with 35" bf goodrich mud terrain tires. I'm not sure how the sizes work as far as bolt pattern, offset, and overall tire go (i.e. 265, 285, etc). Could you explain how the dimensions work and what would you recommend I get? Money isn't necessarily an issue. I currently have an '05 1500 QuadCab 4x4 Laramie with the 5.7L Hemi. Do I need specific parts or suspension pieces to make this fitment work? I am also considering a 3"-5" lift sometime in the future.. not a priority right now though. Thanks.
Carson S.
Carson
Old 02-18-2013, 06:37 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
Try this site for info...
http://www.rimsntires.com/specs.jsp
Old 02-18-2013, 07:53 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
The bolt pattern of your rims will have to be 5x5.5" or 5x139.7mm. If they offer them a 9" wide rim would probably be ideal although anything in the 8-10" wide range would work. With a 9" wide rim you would probably want to go with on offset close to zero or maybe even less to make sure you can run a wide mud tire without rubbing. Offset less than zero becomes negative offset. Common negative offsets are -12, -18, -24, etc. Less offset = more rim sticking out from under the fender.
As for tires, I would probably recommend a 35x12.50x17. That's a nice, meaty tire and a common size in mud tires. With a 9" wide rim with close to zero offset this size will fit just fine. It's also big enough you could probably still run them with a mild lift. I would recommend raising the front end up to level the truck at least with a 35" tall tire. On your 2005 this can be done easily and for only the cost of a front end alignment.
I just checked out the specs on the Fuel Hostage and strangely enough I don't see them listed in a 17" 5x5.5/5x139.7. I do, however, see them listed in an 18" rim. Offsets offered are +1 and +20. If you were to choose this rim for example, you would obviously want to go with the +1 and then a 35x12.50x18 tire.
Hope this helps!
Old 02-19-2013, 10:17 PM
Thumbs up
Wow,
Thank you very much! I now have a better idea of what I'd like to do and what I am allowed with the current setup.
Carson
Carson
help needed, lift kit, questions, ram 1500, wheels and tires
