Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 02-18-2013, 10:11 PM
GymRat's Avatar
GymRat GymRat is offline
Vehicle: 2009 Ram 1500
Color: Mineral Gray
GymRat is on a distinguished road
Default lower strut bolt seized inside bushing... need new LCA?
Today I tried to install my bilstein 5100's and failed miserably. I disconnected everything (swaybar endlink,UCA,tie rod) needed to get the strut out EXCEPT the bottom strut bolt that is housed in a bushin in the LCA. When I try to back the bolt out, the entire bushing rotates within the LCA. I've tried a ton of different things from pb blaster to impact driver and I CANNOT for the life of me get that bolt out. So, defeated, I had to put it all back together and obviously the front end is out of alignment.
Seeing how the bolt is seized inside the bushing, can I replace the bushing or do I need an entirely new Lower Control Arm?
Bilsteins (2.1"), 1.25" RCX, 1" TGC rear spacer, 18" Magnaflow, GREEN high-flow air filter,
billet catch can, white led interior, wade floormats, truxedo cover, cabin filter, 20% tint
Old 03-19-2013, 10:09 AM
Divi Divi is offline
Vehicle: 2011 Ram 1500 Crew cab
Trim Level: Sport, loaded
Color: Obsidian Black Pearl
Rep:112
Divi will become famous soon enoughDivi will become famous soon enough
do you have the nut off? if so put the nut back on a few threads worth and whack that bastard with a nice size hammer to break it free. works everytime for me
2011 Ram 1500 crew OBP, Airraid Cold air, Bestop roll up, Lockpick v5, custom carbon interior trim.
Old 03-19-2013, 10:11 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
i think he figured this out...i cant remember. on a different thread.
i used a sledge hammer and finally got it out but had to use a sawzall to cut the bushings out and replace them.
Old 03-19-2013, 03:55 PM
GymRat's Avatar
Color: Mineral Gray
The struts are on, along with 2 new LCA's and a new pair of sway bar endlinks. Truck has 70k miles so I figured I might as well replace half the suspension lol
Thanks guys
Old 03-19-2013, 06:13 PM
Rep:1900
Thanks guys
what made you go with all new LCAs? instead of just changing the bushings
Old 03-19-2013, 06:20 PM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Cheap Canadian Labour
Rep:1821
Here is the post from his other thread as to why he didn't just do bushings.
Thanks! I tried to do the bilsteins but ended up taking them to the dealer because the lower strut mount bolts were seized in the LCA. I was hoping they could get them out but they couldn't after over 5 hours of trying. I just ended up having them replace the whole control arms, even though Moog makes a replacement bushing. So looking back, I would have just bought the bushings and put them in myself but I already had so much $$ in the install that it would have been a waste to have them put it back together for me to do all of it!
Old 03-19-2013, 06:24 PM
Rep:1900
oh that's right I read that. I'm gettin confused between people
Old 03-19-2013, 07:42 PM
GymRat's Avatar
Color: Mineral Gray
Shawn's right, and here's the thread with pics of everything installed
http://www.ramforumz.com/showthread.php?t=135106
