Seized nut in upper control arm ball joint - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 02-18-2013, 11:59 PM
Nhblkhemiram Nhblkhemiram is offline
Vehicle: 2009 Ram CC
Nhblkhemiram is on a distinguished road
Default Seized nut in upper control arm ball joint
I was installing a Rough Country 2.5" level kit on my 2009 Laramie CC when the nut on the upper control arm (front) ball joint seized on rust 3/4 of the way down. The joint is now free so the nut is just moving with ball joint stud. I've put every lube made on it and even tried holding the end of the stud with box wrench then vice grips. No dice, I can unbolt the arm from the frame to remove strut but still leaves me with a ball joint loose with seized nut. Any tricks out there to fix this issue? Don't really want to buy new control arms/joint included after cutting bolt off. Truck is on friends lift with 34" nittos and 20" XD Hoss wheels waiting and I'm frustrated to say the least. Any help would be greatly appreciated. Thanks-Jay
Old 02-19-2013, 12:30 AM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
PB blaster? Heat nut up with a torch? Jack up suspension to press ball joint shaft back into spindle? All 3?
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 02-23-2013, 05:20 PM
ramit1500's Avatar
ramit1500 ramit1500 is offline
Vehicle: 2012 Dodge Ram Outdoorsmen
Trim Level: Outdoorsmen
Rep:24
ramit1500 is on a distinguished road
Get a long pry bar and get someone to pry down on upper control arm hard it will lock ball joint allowing you to turn the nut instead of the whole ball joint.
Old 02-23-2013, 08:42 PM
RAM EM's Avatar
Color: Grey
Rep:195
Duh. ^^^What he said, I was thinking lower ball joint . Clean any oil or grease off shaft too, it will help it grip in the spindle.
Old 02-23-2013, 08:49 PM
Rep:2968
Torch with Rosebud tip to heat it up & PB Blaster or even better spray it with KROIL, it is more expensive & can be found at most Gun Shops
Good Luck
