Old 02-19-2013, 12:33 AM
MjrWraith's Avatar
MjrWraith MjrWraith is offline
Vehicle: 1998
MjrWraith is on a distinguished road
Unhappy Fed up and ready to scream
Ok so I have had my truck about a month now. The first week I had it I did a full tune-up (distributor cap and rotor, plug wires, plugs, air filter, and coil) now almost as soon as I did this my CEL came on. So I plugged in my scan tool and looked up the trouble code and it was a misfire on cylinder #5. After a couple of weeks, a 180 degree thermostat cause on another forum they said that was better than the OEM....it wasn't now the truck won't heat up past 187 and the problem was actually the coolant sensor. I replaced the coolant sensor and now at least the truck is going into closed loop mode, but still has a CEL. Well after checking plug wires, plugs, cleaning up the throttle body and replacing the IAC, running some seafoam in the tank and through the intake manifold still no change. Oh and I should've said this earlier but when the light comes on it'll idle rough, and when you put it in gear and take off it shutters. It'll smooth out when you get above 10 MPH. I have a plenum repair kit from Hughes on order and last week when i was taking my kids to school I pulled into the school parking lot and the truck just died and wouldn't start. Got it to the shop and the metal strip on top of the distributor rotor was gone and where it use to be was a 1/4 inch scorch mark . Replaced it with another and made sure everything under the cap and the cap itself went on good. Started it up and guess what nothing changed . So I looked into it and found out my cat is gone and one of my oxygen sensors isn't switching fast enough. Would someone please give me some advice on where to look next. Is the plenum my issue cause if so that'll be fixed the end of the week. Any help would be appreciated it feels like all I've done is thrown money at the problem and I have nothing to show for it except a reduced pocket book. Sorry this is so long just wanted to try and give all the details I could remember. If it'll help I'll try to attach the info from my scanner tomorrow. Thanks in advance for the help.
Old 02-19-2013, 03:55 PM
MjrWraith's Avatar
Vehicle: 1998
Ok so I got my ElmScan5 hooked to mu truck today and ran the truck a good 5 miles of city/highway driving. I exported what I could and attached it to see if someone can see something in the data I'm not seeing and please if it seems too simple to point out...point it out I probably missed it . I wasn't able to export the PID values I have them saved if they'll help any. Hope someone can help me get this issue fixed!
Old 02-19-2013, 05:18 PM
RamTech RamTech is online now
Rep:1885
I don't see anything attached to your post.
Old 03-05-2013, 02:33 AM
Dalakian Dalakian is offline
Vehicle: 1996 Dodge Ram 2500 4x4
Color: Red/Black
Dalakian is on a distinguished road
Have you tried running a compression test on cylinder #5? It could be a horrible coincidence, but chances are that one of your cylinders is dead. Highly unlikely, but it could have been cause by seafoaming it. Seafoam probably removed all the built up junk and now the cylinder has lost it's compression.
I would give it a shot - test the compression.
My engine was overheating because my radiator was clogged up. Cleaned it up and now it purrs like a kitten
