Old 02-14-2013, 05:26 PM
Rep:1845
Default 6.1 Hemi Tensioners May Be No Better Than The 5.7
This is mainly for all you out there who have or were debating "upgrading to the tensioner from the 6.1 Hemi to repair or prevent failure of the 5.7 timing chain tensioner/guide assembly. I just finished tearing the cover off of a 2007 Charger with a 6.1 that has lunched its tensioner/guide assembly. At first glance this seems to disprove the theory that the 6.1 design is safe(r) from failure compared to the 5.7 because I have now seen one of each.
Old 02-14-2013, 09:56 PM
I push the skinny pedal
Rep:3277
Overall the 6.1Ls hold up better than the 5.7L ones do when there's more power. With the number that have been swapped in the LX community for this very reason and there are very few issues with the 6.1L timing set. Not saying they're perfect, but they have an extra tensioner leaf than the 5.7L ones.
Kurtis
Old 02-15-2013, 03:58 PM
Color: green
Rep:643
any news or talk of a recall yet ? tks
Old 02-15-2013, 04:05 PM
Rep:1845
No, and at this point it's highly unlikely.
Old 02-18-2013, 06:45 PM
dodge man's Avatar
dodge man dodge man is offline
Vehicle: 2004 Quad Cab diesel
Rep:221
dodge man has a spectacular aura aboutdodge man has a spectacular aura aboutdodge man has a spectacular aura about
Does the 6.1 tensioner and chain bolt in to the 5.7? The 5.7 is VVT and the 6.1 is not. I didn't think they would swap, but I don't know.
2004 3/4 ton Quad Cab, 24 valve 5.9 Cummins
Old 02-18-2013, 08:57 PM
Rep:3277
The 6.1L tensioner will only bolt into the pre-eagle 5.7L. The Eagle timing set is moved further out from the block's face.
Kurtis
Old 02-19-2013, 04:22 PM
dodge man's Avatar
Rep:221
Makes sense, so it would bolt in to 2009 and older 5.7's.
