Old 02-19-2013, 07:44 PM
KMoor91 KMoor91 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Lamarie
KMoor91 is on a distinguished road
Default Air intake
Where does the hose for intake run to? Hose wasn't on my stick one and I got me a aftermarket spectre intake and idk where to run air hose
Old 02-20-2013, 01:48 AM
deathwobble's Avatar
deathwobble deathwobble is offline
Vehicle: 1998 1500 sport
Trim Level: sport
deathwobble is on a distinguished road
There is a oval hole on the inside of the passenger side fender( inside the engine bay) thats what the stock intake connects to. Or are you asking about the breather tube?
Old 02-22-2013, 05:30 PM
Trim Level: Lamarie
Breather tube...I already have aftermarket air intake on
Old 02-22-2013, 08:57 PM
KTM11's Avatar
KTM11 KTM11 is offline
Vehicle: 2001 Sport Ram 5.9l
KTM11 is on a distinguished road
I think your talking about the PCV breather on the passenger side valve cover. There should be a hose that runs from that little elbow piece on the valve cover up to your spectre intake. If your spectre doesn't have one you can pull the PCV valve off and put a small air breather on it. just bypass the hose system
CAI K&N Filter, 2" Skyjacker Coils, 2" Skyjacker Add a Leafs, BFG A/T
Old 03-20-2013, 09:06 AM
ccd1977 ccd1977 is offline
Vehicle: 2000 Dodge Ram 1500
ccd1977 is on a distinguished road
Whatever you do, use the breathing tube and not the PCV valve tube and donot replace the PCV valve. I have a 2000 Dodge Ram and the PCV valve is on the drivers side and the breathing tube in on the passenger side. Both look almost identical until you remove the elbow. If it has a little BB looking thing inside it, that is the PCV. I am making note of this because there were certain years the breather tube and the PCV were switched. Just check before you hook the breathing tube up to your CAI or Air Cleaner.
