Old 02-22-2013, 03:04 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I believe if you buy the prewired ones like the Amazon link, they are just standard, and they are bright. Lets say you use 10 as the running tail lights, then there are 10 for the brake lights. the first 10 will have a certain amount of brightness ( depending on the spacing and number actually used ) then when you apply the brakes the other 10 ( total of 20 lights now or whatever amount are used) add to another certain amount of brightness due to the lights filling in the spaces or covering a larger area.
Only other way you will get dual brightness or a brighter bulb is going with something with a stock base ( bulb socket ) with whatever brightness you pick to use. If you use white with a red lens it will appear brighter, if you use red with a red lense it will be more intense red... so you can use a combination of white and red LEDs for running/brake lights like red for the running and white for the brakes to make the brake lights appear brighter. It is basically your choice and preference. I think you will need an inline resistor for the turn signals, or upgrade your flasher to an electronic one made for LEDs ( kind expensive for a flasher)
Mike
Old 02-22-2013, 04:44 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
You want to run red LEDs for the brake lights regardless of lens color. IF the lens is red you run a red light behind it, its like the tail light leds for the trucks. The lens is red and the bulbs are red as well.
Those LEDs from Amazon are exactly what I was talking about. Run say 10 as a "lights on", run another 10 as a "brake circuit" and then run however many for your blinkers. Im on my phone right now, Ill draw something up on paper and take a picture and show you tomorrow. Itll explain it better.
2011 Big Horn 4x4 -SnowWhite-
Old 02-22-2013, 07:58 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Thanks guys, I really appreciate the help.
Sean
Old 02-22-2013, 08:23 AM
sonocativo's Avatar
Rep:210
Damn, I was hoping you'd go all PowerPoint on us....lol
Mike
Old 02-22-2013, 08:31 AM
snrusnak's Avatar
Rep:1385
So here's what I get so far:
I have a red lens(I think it has a "refractor" or whatever it's called, that spreads the light....is this ok?) I believe I could buy an aftermarket clear lens which might look cool.
I'll get the red LEDS for running and brake lights. I'll figure out how many I want a little later after I understand this whole setup better.
So I'll have red running lights then when you apply the brake I can have say twice the amount of red lights light up for the brake, and it will be twice as bright?
Then I can get amber LED's for the turn signals, and again figure out the wiring later once I understand the setup more...
Am I on the right track now?
Sean
Old 02-22-2013, 09:31 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
But I relieve you are.
brad
Interested in one of my mods?
Old 02-22-2013, 10:09 AM
ShawnC13's Avatar
Cheap Canadian Labour
Rep:1790
Brad is this your motivational poster that you have over your desk at work? You must have heard this saying before many times!
Sean sounds like this will be a great looking setup when you are all done!
Old 02-22-2013, 10:29 AM
snrusnak's Avatar
Rep:1385
^I hope so! Will take some doing but should turn out nice, and then I'll have a new skill lol.
Sean
Old 02-22-2013, 10:38 AM
ShawnC13's Avatar
Rep:1790
First get this new skill then we will work on helping you spell your name.
Old 02-22-2013, 11:04 AM
sonocativo's Avatar
Rep:210
A little simpler would be.... if you had 20 lights total, half would run as regular running lights, when you apply the brakes the other half will light up increasing the amount of light.
You can mix them together in one area like a dual filament bulb or seperate them like a 2 bulb setup. I will try and do a drawing as well.
Mike
