Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
ZDOG
Old 03-03-2012, 12:11 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Leveled 4th Gen RAM 1500 - Total Load Control Works
2009-12 RAM 1500s equipped with standard body lifts and leveling kits are suitable for TLC in MOST cases.
If you're not sure, please email us the make and model number of your kit and truck and we'll let you know for sure.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 04-25-2012, 06:54 PM
Jorde's Avatar
Jorde Jorde is offline
Vehicle: 2011 Ram 1500
Color: silver
Jorde is on a distinguished road
Thanks to everyone at TLC. I now have there setup with the compressor in my 2011 sport. I havent had any issues and can pull a 10000 lbs bumper pull trailer and and have my truck sit level with only 15 psi in them, HUGE IMPROVEMENT from stock. The guys there are also a ton of help, any questions or concerns the guys were very quick to answer.
As far as putting it in a leveled truck it works good too because my truck has a 2.5" spacer on the rear and Im running 3psi in the bags always just to make sure but dont even need that.
Thanks everyone at TLC. GREAT PRODUCT!!!!
Old 06-19-2012, 05:27 PM
Snap's Avatar
Snap Snap is offline
Vehicle: 2013 Ram 2500 CC 4x4
Rep:12
Snap is on a distinguished road
Are Dodge dealers willing to install these kits?
I'm use to having auto ride air suspension so I will be getting the TLC, I'm just not able to self install and I want to make sure the dealer will do it without giving me grief.
2013 Ram 2500 Cummins CC 4x4 Big Horn
2011 Bayliner 245SB
Old 06-19-2012, 05:52 PM
TLC John's Avatar
Rep:17
Default Dealer install
Not sure if any pushback on a dealer install.
We do have them being installed by Towbin Dodge in Las Vegas - they are largest Dodge dealer anywhere.
If your local dealer will not, its an easy install that could be done by almost any repair or performance shop. No modification required.
Total Load Control™
Old 06-20-2012, 11:43 AM
Snap's Avatar
Rep:12
I was looking underneath and noticed two yellow "balls" (for lack of a better term) in the same position as I would expect to put the TLC air suspension. Do those yellow things get removed as part of the install?
2011 Bayliner 245SB
Old 06-20-2012, 06:29 PM
TLC John's Avatar
Rep:17
Default Remove Jounce Bumpers
Yes, those are Jounce Bumpers. You remove them when you install TLC.
Total Load Control™
Old 06-20-2012, 08:49 PM
LC Hauler's Avatar
LC Hauler LC Hauler is offline
Color: Bright Metalic Grey
Rep:72
LC Hauler will become famous soon enough
the jounce bumpers come out with a light pull.
I will get some feedback from dealers tomorrow as I'm stoipping by a 4 of them tomorrow with eth trailer on teh truck. should see some interest.
Old 02-19-2013, 11:47 PM
dougp47 dougp47 is offline
Vehicle: 2011
dougp47 is on a distinguished road
Jorde I just ordered my tlc and wireless control today. I would like to ask a question on setting up your hitch. What kind of changes did you have to make to you hitch set if any? I have the ez-hitch with 10000 bars. I'm thinking I might need to make adjustments to the shank setup,like lowering the shank. I was going to take measurements from level on the truck and TT, any help would be great.
