2013 RAM 1500 CC Sport 4x4 build thread - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-23-2013, 02:23 AM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Vehicle: 2012 Ram 1500 Laramie CC
Trim Level: Millennium Falcon
Color: Mineral Gray Metallic
Rep:1503
KA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant future
The red is definitely an eye catcher.. and a speeding ticket on the first drive home?! LOL! Perhaps that's what my dad meant when he called his Thunderbird's color 'Arrest Me Red'!
Just out of curiosity, I noticed you have a black front license plate bracket.. could you tell me if it has a part number on it? My truck should've come with a bracket, but I suppose they believe two bolts are sufficient. My front plate rubs against the chrome bumper.. not good. Really hoping your bracket will fit my bumper.
Old 05-23-2013, 08:55 AM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
Not sure what the PN would be for the bracket but couldn't too hard to find through Mopar.
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 05-23-2013, 09:12 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Yup!
Looks killer man
sales@revelperformance.com
Old 05-24-2013, 09:52 PM
Ferrato81 Ferrato81 is offline
Vehicle: 2010 Dodge RAM 1500
Color: Grey - Two Tone
Ferrato81 is on a distinguished road
Probably a stupid question, but what's up with your head lights? Looks like they were dark in the original pictures. Are they an upgrade? Truck looks great by the way.
Old 05-26-2013, 12:39 AM
514RAM's Avatar
514RAM 514RAM is offline
Vehicle: 2013 DODGE RAM SPORT QC 4X4
Trim Level: SPORT
Color: BLACK
514RAM is on a distinguished road
Originally Posted by hemipowerv8 View Post
OK - got the truck back with a whole new ZF trans in it so hope to be DONE with issues! Had the exhaust redone custom cat back...Magnaflow Y into Magnaflow 18" to dual out stock pipe from there and stock tips (for now- looking for black 4-5" replacements).
Also did the Bilstein 5100s all around, 2.1" lift front and a TGC .75" spacer in the rear. Looks about level but there is a 1" difference right now it seems...perfect rake! I have 7" clearance over the front stock tires and 8" in the rear. New tires will soak up .75" of that next week so will be about stock looking rear fender space and about 1.2" added front clearance so SHOULD look right as if the 35s belong on there!
Had the grille swapped to a black one and tow hooks installed. Will do tires next week when they come in - 35x12.50 Toyo Open Country AT. Have custom made hub and wheel centric spacers that are about 3/8" thick (.375 looks like as evidently you can't have hub AND wheel centric at only .25") - I am not that comfy with daily driver having nearly half an inch spacers on it though...but could only be hub centric if I went with 1/4" which maybe I will get a set and try...I had my last set only hub centric and they were ok for years.
A couple photos:
How did you go about installing the tow hooks? Did you cut out the holes directly on the truck or did you remove the insert, and then cut the holes?
Old 05-26-2013, 12:46 AM
Revel Performance
Rep:1804
That plastic tray can be removed and trimmed/cut for the tow hooks.
There are a few DIY threads on here somewhere explaining how its done.
But it's pretty straight forward.
Old 05-27-2013, 11:16 PM
Rep:74
Thanks! No these are the stock sport 2013 headlights.
Old 06-04-2013, 09:58 AM
DarthRam's Avatar
DarthRam DarthRam is offline
Rep:1543
Did you NEED to use the wheel spacers or did you WANT to use the wheel spacers? I am looking at the same tires for my 13 Sport.
Thanks.
Old 06-04-2013, 10:32 PM
Rep:74
If you are using the stock sport wheels and same size tire (12.5" wide) you will need 1/4" spacers. I had some made that were wheel and hub centric and in order to do that they had to be a bit over a 1/4" so mine are 3/8" which is the max I would run. I am considering new wheels but CAI and ported tb and tuner will be first so maybe wheels next year. Maybe...
I prefer not to use wheel spacers but its the only way not to rub the A arm pretty bad. Unless you never plan on turning lol.
Old 06-04-2013, 10:58 PM
Klus01's Avatar
Klus01 Klus01 is offline
Vehicle: 2013 Dodge Ram
Klus01 is on a distinguished road
Truck looks awesome! Keep up the good work.. keep us posted once ya put the vararam in. Im curious how they fit in the 8 speed with active grille shutters.
