Old 02-20-2013, 02:35 PM
tclark's Avatar
tclark tclark is offline
Vehicle: 2009 Dodge Ram QC
Color: Deepwater Pearl
tclark is on a distinguished road
Default 60,000 mile service, $&@#
Well, I just got off the phone with the service dept. about getting a price for a 60,000 mile service. They want just shy of $1100. My initial reaction was what the heck, just a little more colorful. I called another service dept. and they wouldn't give me a price. So it looks like I'll just start doing my own maintenance like I used to on my previous vehicles.
Old 02-20-2013, 04:48 PM
Kcbigbadram's Avatar
Vehicle: 2014 1500
Trim Level: limited
Rep:503
what all were they saying needs done?
Old 02-20-2013, 06:37 PM
tclark's Avatar
Engine oil and filter, transmission flush, oil and filter, rear diff flush and oil, air filter, spark plugs, and a few other things that are part of their "package deal". I don't think it adds up so I'm just gonna do it myself.
Old 02-20-2013, 07:08 PM
Arth's Avatar
Arth Arth is offline
Color: Deep Cherry Red Crystal Pearlcoat
Rep:2035
Do it yourself. I did and it saved me a TON of money. The labor rate they charge is unreal.
Chrome... in moderation.
Old 02-20-2013, 07:12 PM
I push the skinny pedal
Rep:3308
Do the oil/filter and plugs, but you can leave the tranny and diffs since they really don't need to be changed until 100K miles. Check your air filter, if it's dirty then change it, if not save the $10
Kurtis
Old 02-20-2013, 07:22 PM
Rep:2705
Read your Owners Manual, starting at Fluids & Capacities, page 488
then Maintenance Schedules, page 492
Unless your are running a taxi, ambulance, tow heavy loads often, etc. you don't need to change transmission fluid or the 2 filters in it, i did just for peace of mind & i wanted to run Royal Purple fluid
I changed the rear end fluid to have Royal Purple fluid & i wanted a cover with a drain plug that is magnetized, dodge covers don't have drain plugs, so you have to pull the cover & then re-install it each & every time. If there is no metal shavings on the magnetic drain plug, why pull the cover off
60,000 Miles (100,000 km) or 60 Months Maintenance Service Schedule
❏ Change the engine oil and engine oil filter.
❏ Rotate the tires.
❏ Replace the engine air cleaner filter.
❏ Replace the ignition cables (3.7L Engine).
❏ Replace the spark plugs (3.7L and 5.7L Engines).
❏ Inspect the brake linings; replace if necessary.
Change the automatic transmission fluid and filter if using your vehicle for any of the following: police, taxi, fleet, or frequent trailer towing.
Change the transfer case fluid if using your vehicle for any of the following: police, taxi, fleet, or frequent trailer towing.
❏ Flush and replace the engine coolant at 60 months if not done at 102,000 miles (170 000 km).
❏ Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play;
Old 02-20-2013, 07:24 PM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
Well if it were MINE and I was planning to keep the truck BEYOND 100k miles I would do all that but do as much as I can myself...plugs and oil/filter would get done for sure...but honestly the plugs in our trucks are a time consuming job and I may pay to have that done...still everything listed on the 60k service shouldn't run over $800 I'd say unless you are running all Royal Purple fluids front to back...I would try another reputable shop.
Now- the coolant flush, diff and trans flush and new fluid CAN go until 100k miles but if you plan to run the truck to lets say 200k miles I would do all that at 70k and again at 140k...just to be sure you don't shorten the life of any components. If you plan to be out of it around 80k for example...I would do plugs, oil/filter, top fluids off and just check for issues with the others. Period.
All depends on your plans...
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
^^^^ What he said, although I have already replaced my diff fluid.
sales@revelperformance.com
Old 02-20-2013, 07:29 PM
Rep:2705
120,000 Miles (200,000 km) or 120 Months Maintenance Service Schedule
❏ Rotate the tires.
❏ Inspect the CV joints.
❏ Inspect exhaust system.
Change the automatic transmission fluid and filter(s). this is the first time it reads to change it
❏ Change the transfer case fluid if using your vehicle for any of the following: police, taxi, fleet, or frequent trailer towing.
❏ Replace the accessory drive belt(s).
Old 02-20-2013, 08:08 PM
Rep:3308
Remember, there is a difference between factory recommended (minimum requirements for warranty) and dealer recommended (more often so they can make money), and some fluids do NOT need to be changed that often.
Kurtis
