Old 02-21-2013, 03:41 AM
2012Cummins 2012Cummins is offline
Vehicle: 2012 Ram 2500 Cummins
Trim Level: Limited
2012Cummins is on a distinguished road
Default 2012 RAM 2500 6" Lift - Do I need to extend my drive shaft?
Hello all,
I have a question...
I am going to put a 6" lift on my 2012 ram 2500 diesel and i read on the Carli site that I would also need to extend my driveshaft by two inches. This is the part that scares me since if that thing is not perfectly balanced i may run into some trouble down the road. Should I be worried? Do i need the extension? Is this something that people normally do when lifting 6"+?
Any advice that you guys could lend would be extremely helpful.
Thanks,
Sean
Old 02-21-2013, 06:41 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
most kits come with a driveshaft spacer that will extend it... some people dont even use it. i dont think you will have any issues
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 02-21-2013, 10:44 AM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
Agreed. Mine came with a spacer.
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 02-21-2013, 01:02 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
Wow that thing is going to be HUGE! HD's with lifts look pretty badass. Anyways, agree with the above comments. Most kits will come with a spacer. I'd definitely look into a quality lift though since that will be a big, heavy truck
Old 02-22-2013, 02:59 AM
Trim Level: Limited
Well I was thinking of putting on the Carli Performance 2.0 6" lift, and I guess they do not make a spacer becuase the guys there are telling me that I need to go to a shop and have the driveshaft cut and welded back together which just sounds like a really bad idea to me.
I need to look into this spacer that you guys are talking about. Exactly where is the spacer placed? I have a two piece drive shaft.
Thanks again
Old 02-22-2013, 03:18 AM
Ram725's Avatar
Rep:347
Carli is a whole other level. If you get their kit do what they recommend. They are by far the absolute best in the business.
Build Thread
Old 02-22-2013, 03:21 AM
Trim Level: Limited
I have no problem doing what they suggest but they do not personally due the 2" shaft extension... so I am lacking info on how to get the job done.
