Old 02-21-2013, 07:42 PM
Marine7212's Avatar
Marine7212 Marine7212 is offline
Vehicle: 2012 Ram 1500 regular cab
Trim Level: tradesman short bed
Color: Dark Grey
Marine7212 is on a distinguished road
Default 17s to 22s
giving my ram with 17s the street look with 22's. is there a tune or something to correct my speedo? when I put on 22s and lower it with 2/3 or 2/4 drop will this be about the same ride height it is now>?? I like my ride height but want better handling and looks
Old 02-25-2013, 09:58 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Your rim size has nothing to do with your ride height. That is relevant on tire size.
I'm going to 24s on a 3/5 and will be lower than stock. I'm also going to body drop my truck as well after the suspension drop.
If you want your truck to sit the same height you'll need a truck with a larger sidewall
2011 Big Horn 4x4 -SnowWhite-
