Old 02-21-2013, 07:53 PM
Flight-ER-Doc Flight-ER-Doc is offline
Vehicle: 2010 Ram 1500 Crew
Color: Inferno Red
Flight-ER-Doc is on a distinguished road
Default Serv 4wd
OK, this is a puzzlement....
Almost every time I put the truck into 4WD (mostly 4WD Auto) the Serv 4WD light goes on, and doesn't go out unless I turn the truck off. I
I've been to the dealer, they replaced the transfer case module twice (the first time the replacement was DOA). I should note that the dealer says that there are no trouble codes being generated. Last Tuesday they replaced the module again, with a good one. On the way out of the dealer, I tried it and it seemed to work OK - 4WD light came on then went off, no service light.
Today driving to work I put it into 4WD thanks to the city of Ottawa doing their usual job of clearing roads, and the Serv 4WD light goes on. And stays on. I can't get it off right now, shutting the car down then restarting and the light is still on.
So, back to the dealer next week when I have time, and see what the problem is...
Any ideas? That extended warranty is looking like a better and better idea.
Old 02-21-2013, 08:25 PM
48pege 48pege is offline
Vehicle: 2011 Ram 1500
Color: Rugged Brown Gold trim
Rep:32
48pege is on a distinguished road
Don't know about the new trucks but on my '97 sometimes after extended driving in 4wd I have to put it in reverse and back up a little to get it to come out of 4wd.
Harvey
Old 03-05-2013, 12:17 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500; 2010 RAM 1500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
Harvey
^^^&Exactly what IU was going to suggest. Old 4x4 issue where the drive train needs to unbind to release. Sometimes it takes several attempts. Be sure your tires are forward facing (seems obvious but you'd be suprised who would try this with the wheels turned).
2010 1500 Laramie Hemi: Magtec Rear Diff cover, 24" Magnaflow, Resonator delete, Line-X; Bilstein 2.75" kit;295/60-20 Wrangler Silent Armor Pro Grade; Lift Air Bag
2016 3500 Laramie MC: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
