rough country 6inch lift? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-21-2013, 08:08 PM
Bigfish Bigfish is offline
Vehicle: 2012 Dodge Ram
Trim Level: Lone stare
Rep:13
Bigfish is on a distinguished road
Default rough country 6inch lift?
Okay so my income tax came in and the gf/wife gave me permission to get a lift and tires. My plan is to do a 6inch lift with fuel wheels (haven't decide which ones) and 37inch tires. My shop is saying that the rough country lift alone will fit 37 and it will be level with out bilstines. I also plan to get a trinity tuner. They are also telling me that i will be fine not regearing it. Is this all sound correct?
Old 02-21-2013, 08:12 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
your wife AND your gf? nice nice do they know? :Lol: jk
sounds good to me, I'm no lifting expert so others will chime in. can't wait to see your set up! must have been a nice return gettin all this! it's gonna be a pretty penny.
Old 02-21-2013, 08:17 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
I have a 6" RCX with my bilsteins at 2.1" with no added lift to the rear and I sit nose high by .75". With bilstein at 1.4" you will sit level. So you will not be perfectly level with just the 6", however it will no be overly noticeable.
With my 8.1" of lift I still rub on 37s, but this can be because I have 20x10 Fuel wheels.
You will be fine without regearing but it will not be perfect. I have 3.55 (even 3.92) and I definitely lost power and mpg. It also much harder on my trans. Now am I happy with my setup? Absolutely. Would 4.56 be a much better modification? absolutely! You will be no where near stock with stock gears. For me it is just enough to keep me satisfied. They are probably telling you that because re-gearing a 2012 is a PAIN!
My build thread is below if you wants pics etc.
If you have any other questions let me know.
Where in TX are you?
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 02-21-2013, 08:31 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Yep, sound like what I did. I have the 6" RCX lift, 37" Nitto Trails on 20X12.5 Moto metal wheels with 0 offset...no rubbing. Mine doesn't sit exactly level but after you have it done, you won't care!
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 02-21-2013, 08:35 PM
Rep:13
Im from pearland just south of Houston. I will be using a shop in Manvel called texas performance and off road.
Old 02-21-2013, 08:47 PM
Ram725's Avatar
Rep:347
I know exactly where that is. I grew up in Katy (W. Houston) and had a shop in Katy do my setup.
Build Thread
Old 02-21-2013, 09:06 PM
Rep:13
I dont have a enough post to pm yet.
Old 02-21-2013, 09:54 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
the reason he is rubbing is he has toyos which measure in at 14'' wide... if you go with a 12.5 you will be fine and wont rub. sounds like it will be great but it will be sluggish no matter what your gearing is it wont be the same at all..
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 02-21-2013, 10:02 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
The RCX 6 inch kits here my buddies have don't sit perfectly level. They do look good as is though, IMO.
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 02-21-2013, 10:06 PM
Ram725's Avatar
Rep:347
Good point....
And I agree about the re-gearing
Build Thread
