Old 02-21-2013, 07:19 PM
sundawg21 sundawg21 is offline
sundawg21 is on a distinguished road
Default keep getting check engine light
I have a 2005 1500 5.7L and i had a check engine light on for the #1 oxygen sensor in bank 2. I ended up replacing all 4 sensors when this first happened because it was time to do so anyways. After changing all of the sensors and clearing the code everything seemed fine. Now I get the P0132 code on and off. I will reset the computer and then a couple of hundred miles or so the code comes back. When it does throw the code again, it always does it when the truck is at an idle like in the mornings when i let it warm up b4 i drive it. Was just wondering if anyone had any suggestions about this problem? Thank you!
Old 02-21-2013, 08:33 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
6.4L HEMI Driver
Vehicle: 2014 Ram 2500 CC 6.4L HEMI
Rep:58
ShiftJockey will become famous soon enough
Check to make sure the connection is clean, the connector is not cracked or damaged and that the harness is not torn.
Michael
2014 BIG HORN CREW
6.4L HEMI
