Old 02-21-2013, 11:43 PM
Cheatham Cheatham is offline
Vehicle: 2012
Color: Grey
Rep:17
Cheatham is on a distinguished road
Default Interior wind noise found
Like many who have said they have a mystery wind noises i had one and i cycled my recirculate vent switch and it goes away with outside air in, i opened and removed glove box and cycled the swich found the door inside the blower and messed with it and went for a drive and no more noises like driving with a cracked window.
Old 02-22-2013, 12:04 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
OH man I sure wish you had posted this yesterday!!!! I spent all day on the road today with that damn whistle, just cranked the stereo instead! I'm going to try this tomorrow!!!! Oh and what exactly did you have to do to the door?
Big Red my old 2011 Sport
Old 02-22-2013, 08:57 AM
Tom in ct.'s Avatar
Tom in ct. Tom in ct. is offline
Vehicle: 2012 Dodge ram 1500
Trim Level: express
Color: dark cherry red
Tom in ct. is on a distinguished road
Mine sounds like the driver side window is leaking. but could never pin point the spot. going to try what Cheatham did. Thanks for the info....
Old 02-22-2013, 05:32 PM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
could you expand on the "messed around" and be a bit more specific? tks.
Old 02-22-2013, 08:43 PM
GrayhemiST GrayhemiST is offline
Vehicle: 2012 Ram Hemi Regular Cab
Color: Mineral Gray
Rep:277
GrayhemiST is a jewel in the roughGrayhemiST is a jewel in the roughGrayhemiST is a jewel in the rough
interesting.......please give some details on the glove box procedeure...thanks
Old 02-22-2013, 09:12 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
If at all possible can you post your steps that you took along with some pics....Thanks for the info......
Old 02-22-2013, 10:53 PM
Vehicle: 2012
Color: Grey
Rep:17
I just opened the glove box and it will snap off and get it out of way i laid on my back and you can reach your hand into the glove box area and with the truck running and fan blower on cycle the rec switch and i had my fingers inside the grill of the blower motor and you can feel the door open and close, idk exactly what i did but as the door closed i just pushed it with my fingers to be sure it was closed and cycled the switch again and then pushed on the door to be sure it closed all the way i couldnt tell if i made a difference but i could feel that it wasnt hanging slightly open so i got on freeway and it didnt whistle aka wind noise anymore. Before i did this i was checking door seals and making sure the window was rolled up completly and the one day i happen to hit defrost and it went away the rec switch will go to outside air when defrost is on and whistle stopped, maybe a leaf or or piece of trash got in and kept it from sealing or it just got hung up, sorry i dont have pics to show qhat i did but its a simple procedure.
Old 10-12-2013, 08:49 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
The rec switch has NO effect on the turbulent wind noise on my 1500.
Old 10-13-2013, 04:39 PM
roo roo is offline
Vehicle: 2013Express,2014 Charger R/T
Rep:44
roo is on a distinguished road
I thought it was my ears, seems to do it with everything but the off!
Old 10-13-2013, 04:55 PM
Rep:2705
For those that are new to Ram trucks
If the glove boxes are the same as they have been in the past
first empty them
then the lower glove box sort of squeezes inwards from the sides & that allows you to remove the box.
Then if you look at the bottom of the upper box, you should see 1 screw, take it out & that allows you to remove the upper box.
You can then see just about everything behind there
If you look closely, you will also see a dotted line ? in the cardboard covering the firewall, that can be trimmed out & you can then install a cab air filter, if you so choose
you should also be able to see the some of the area behind the radio, in the 2009 Rams, they hid the USB cable behind there on some models
