Old 02-22-2013, 10:08 AM
NRMOBILETECH NRMOBILETECH is offline
Vehicle: 99 dodge ram 5.2 4wd
NRMOBILETECH is on a distinguished road
Exclamation 5.2 misfire
ok i have a 99 dodge ram 1500 4wd 5.2 getting misfire code cylinder 8 started with cylinder 7 i put plugs wires cap rotor coil stator and pulled the injectors on cylinders 1,3,5,7 and when i cleaned them and put them bak the misfire code went to cylinder 8 i have done a compression check all good there and i followed the tsb on lug wire routing but still getting misfire on cylinder 8 gettin little frustrated lol any coments??? no plugs are getting coated in oil
Old 02-22-2013, 10:13 AM
Rep:1885
Has the intake plenum pan gasket ever been replaced?
Old 02-22-2013, 10:19 AM
no not yet i was thinkin the same but none of the plugs looked coated just seein if anyone else had same issues resorting in another problem before i tear down the intake
Old 02-22-2013, 10:53 AM
Rep:1885
Checking for a blown plenum pan gasket is going to be the next step since you've already covered the secondary ignition.
Old 02-22-2013, 12:04 PM
also the only thing keepin me away from the intake gaskets is no leak down on compression test
Old 02-22-2013, 01:18 PM
Rep:1885
A compression test will not show you the same things a leak down test will and it won't show you a blown plenum pan gasket. You need to follow this bulliten in order to correctly diagnose a blown plenum pan gasket. http://www.ramforumz.com/showthread.php?t=46305
Old 02-25-2013, 10:44 PM
Loganm Loganm is offline
Vehicle: 1998 dodge ram 1500
Color: Blue and silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Loganm is on a distinguished road
I'm having the same problem with my pickup except I had the spark plug on my cylinder 8 break apart. I changed out the plug but wasn't able to find the ceramic piece that broke apart. It ran fine for about 500 miles, now my check engine light is back on and the code reads the same cylinder 8 misfire
Old 02-27-2013, 07:44 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Well, Logan, I had the exploding spark plug problems with my 98, the pieces all went thru the exhaust just fine, (several times) but to cure the #8 detonation, I had to replace the plenum gasket. I couldn't figure out what was causing the #8 misfire, and detonation, with the exploding spark plug prob, for a long time, initially, now any misfire code pretty much tells me that the prob is that flippin gasket.
