Old 02-22-2013, 02:16 PM
dwilke02 dwilke02 is offline
Vehicle: 2011 dodge ram 1500
Trim Level: st
Color: flame red
Rep:50
dwilke02 will become famous soon enough
Default Offset and backspacing help: 18" fuel hostage on 35x12.5 trail grapplers
I'm about to order tires and rims today for my 2011 ram 1500 leveled. I was wondering if I could do the -18 offset without any rubbing and what backspace I should do. I really want the tires to stick out. Any suggestions please. Thank you 18" fuel hostage on 35x12.5x18 trail grapplers
2011 Ram 1500 flame red 4x4...... tinted windows, recon cab lights
Old 02-22-2013, 03:58 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
-18 offset should be plenty enough to clear 12.50's without rubbing. If you stick with a 9" rim you are basically moving the rim and tire out from under the truck about 1.4". That combined with the 12.50" wide tire will definitely make it stick out. As for the backspacing....it's basically a product of the offset and width. If you already know the offset and width that you want, then you don't need to worry about the backspacing. If you stick with a -18 offset then the only way to change the backspacing is to change the rim width. Make sense? Hope this helps.
Old 02-22-2013, 04:20 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
To further explain what this guy said... A -18 offset on a 9" wide rim gives you a backspacing of +/- 4.25". A -18 offset on a 10" wide rim gives you a backspacing of +/- 4.75". From what I've read on forums you can get away with a 5" backspacing with 35x12.5 tires and a leveling kit with no rubbing (possibly some at full lock). So with either of those wheels rubbing shouldn't be an issue. It just depends on how far you want your tires to stick out of the truck. Here are two good sites I found to help you visualize the size of each:
http://www.willtheyfit.com/
http://www.rimsntires.com/specs.jsp
