United Radio
Old 02-22-2013, 03:36 PM
Nicksram Nicksram is offline
Vehicle: 2012 ram 1500
Nicksram is on a distinguished road
Default Tire fitment help
Hey guys i just bought some 18x9 wheels with +1 offset, looking at getting some 285/75r18's will those clear without rubbing? Trucks also lifted cst 4/1
Old 02-22-2013, 06:45 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1990
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
Originally Posted by Nicksram View Post
Hey guys i just bought some 18" wheels with +1 offset, looking at getting some 285/75r18's will those clear without rubbing? Thanks
Need more information than that to tell you if they'll fit or not. The same offset on two different width rims will give you a different backspacing. So no one can really answer this without knowing what width rim you're going with. Check out these two sites. They'll help you out.
http://www.willtheyfit.com/
http://www.rimsntires.com/specs.jsp
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover | 5000K Morimoto HID's (lows and fogs)
