tonneaucovered.com
Old 02-25-2013, 05:42 PM
tat2dwiseguy's Avatar
tat2dwiseguy tat2dwiseguy is offline
Vehicle: 2012 RAM 1500 SPORT
Color: Deep Cherry Red Pearl
Rep:64
tat2dwiseguy will become famous soon enough
You might be able to cut another inch out of the rears, but they are a progressive spring so you will screw with their rebound.
As for the fronts, I wouldn't go much lower on a 4WD, as your half shafts will begin to bind.
Originally Posted by blacknchromehemi View Post
so how much can i cut off the springs i would like to drop it like 3 / 5 or maybe even 4/6
Old 02-25-2013, 10:23 PM
I push the skinny pedal
Rep:3308
GF is the only kit that's marketed for the 4wd... but the 2wd kits work just fine, you just won't have a parts warranty because it's "not the intended use". I am installing a McG's 2/4 kit on my '09 4wd and contemplating cutting the springs to a 3/5, which is about as low as you can take the front before you start having CV issues.
i was kinda hoping to get the mcg spindles and the belltech kit and cut the rear spring an inch to get a 4/5 does anyone see any issues with doing this?
You will be at too much of an angle on your front CV joints and you'll wear them out or just plain ol' snap them when you put the pedal down in 4wd. I've seen it before, not pretty. You can always just do the spindles and get the rear spring kit, or just stick with springs, many ways to skin this cat.
Kurtis
Old 02-26-2013, 10:34 AM
blacknchromehemi's Avatar
blacknchromehemi blacknchromehemi is offline
Vehicle: 2012 ram 1500
Trim Level: big horn
Rep:14
blacknchromehemi is on a distinguished road
hmmm guess im thinking i will go with belltech and maybe cut the coils CDnoil let me know how cutting the coils to 3/5 works out
Old 02-26-2013, 11:01 AM
TLSXD's Avatar
TLSXD TLSXD is offline
Vehicle: 2012 Ram 1500
Trim Level: Limited
Rep:17
TLSXD is on a distinguished road
I didnt realize the 2wd lowering springs (belltech) would work on struts?
2012 Ram 1500 4x4
Laramie Limited
GROUND FORCE - SRT 22 - TOYO - SPOHN - HELLWIG - BORLA - ARH HEADERS -RETRO HID - UNDERCOVER - LINE X - BILLET TECH - TRINITY (collecting dust)
Old 02-26-2013, 12:41 PM
Rep:14
???? i would like ot hear from someone who has the belltech on thier 4wd
Old 02-27-2013, 11:55 AM
Rep:14
bump anyone have the belltech kit on their 4x4
Old 02-27-2013, 12:26 PM
TLSXD's Avatar
Trim Level: Limited
Rep:17
Like I said, I dont think you can put the 2wd front springs on the 4wd struts. Two different front ends.
2012 Ram 1500 4x4
Laramie Limited
