Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-22-2013, 07:24 PM
jfreddy jfreddy is offline
Vehicle: 1999 Dodge Ram 1500 Sport
Trim Level: SPORT
jfreddy is on a distinguished road
Default Odd Coolant Leak
Ok so I just bought a 99 Ram 1500 Sport. 4x4 5.2 Auto with A/C.
I just been going through the truck making sure there are no unkown problems before I start driving it and I found a coolant drip but can't follow it anywhere.
It's on the passenger side corner bolt of the oil pan is where I found it. It's all dry above (leading towards a head gasket or intake manifold, which is what I first suspected). Also I checked from what I could see all around the water pump and t-stat housing but couldnt find anything leading to that spot either.
The truck is low on coolant, still some near the top of the rad but the overflow was empty. So I'm just wondering if anyone else has found a coolant leak in that general area. I'll try a pressure test and see if I can find anything. But being lazy haha I figured I'd post here first and see if anyone can shortcut me to the issue
Old 02-23-2013, 09:34 AM
Rep:1845
Thermostat gasket is the most common point for leaks on these trucks and it's easily overlooked because of its location.
Old 02-25-2013, 11:42 PM
Trim Level: SPORT
I will definetly take it apart and take a closer look at it for sure. But I also read on here that there are frost plugs in the rear of the block that you have to take the trans out for access to them. From what i've read it related closely to the leaks location and trail.
Old 03-17-2013, 07:17 PM
CBW1999 CBW1999 is offline
Vehicle: 1999 Ram 1500 Sport
CBW1999 is on a distinguished road
Too funnny.... I recently bought a 99 and am seeing very close to the same leak and pulling what little hair I have left- trying to find its point of origin.
I'm pulling the intake manifold this week to replace all the gaskets and will look closely at the t-stat housing. I bought the kit that has everything in it so it was going to be replaced anyway but, now I am really curious if it was coming from there.
Old 06-02-2013, 01:08 PM
barra340 barra340 is offline
Vehicle: 2001 Dodge Ram
Color: wht
barra340 is on a distinguished road
II have a 2001 5.9 and had the leak on the drivers side. It leaks out of the front of the intake when the truck sits after running. Leaks down with a slow drip. I couldn't see mine either. Thought it was water pump. Took me a while to figure it out.
Old 06-05-2013, 10:44 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
Unsure if the OP found his leak, but here are some other typical places to check. Also, some can only be found by using a paper towel and at the moment of shutting off...
1. Heater core hoses in/out
2. Water pump on the bottom side
3. Upper Rad Hose to the IM
4. Bypass hose
5. Water Pump Inlet Pipe - oring there likes to deteroriate. This one is either obvious or need a paper towel next to it wick the liquid. Sometimes only seen seconds after shutdown b/c of back pressure.
Always look for remnants of dried up crystals
These are basic checks that don't require removing parts.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 07-28-2013, 04:55 AM
tox's Avatar
tox tox is offline
Vehicle: 2000 Dodge Ram Sport
tox is on a distinguished road
4. Bypass hose
I would also add the timing chain cover gasket to that list. Mine was leaking badly.
2000 Dodge Ram 1500 Sport 360 quad cab loaded. Kegger mod: http://goo.gl/hXl48Z
