Old 02-22-2013, 07:30 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Default Side step mounts
Hello everyone:
I've recently received the nerf bars that I ordered for my '10 CC 1500.
I had to remove the OEM side steps in order to install the new ones. The OEM step bars came off very easily. What's not so easily is what I think are the "well nuts". They appear to be pressure sealed into the underside of the body.
These are the nuts that the OEM mounting brackets were bolted to. There are 3 sets of 2 on each side. According to the instructions with the nerf bars, I'll need to reuse at least one hole on each set.
Is there any way of getting these out short of drilling? They're of a different size than the mounting screws/ brackets on the new nerf bars, so I don't believe that I can reuse 'em.
thanks everyone
Exco
Bill
Old 02-23-2013, 11:22 AM
Rep:1845
Drilling/grinding is the only way to remove them.
Old 02-23-2013, 03:08 PM
Excoastie's Avatar
Rep:1358
Ok thanks Randy. I appreciate your help.
I was figuring on having to drill 'em out, but was hoping otherwise.
Exco
Bill
