tonneaucovered.com
Old 02-22-2013, 09:44 PM
ukonathome ukonathome is offline
ukonathome is on a distinguished road
Default Push button start issues
When I first bought my 2013, you would just touch the button and it would start. I got a recall to bring it in and have the daytime lights activated. After this update was preformed it changed the start sequence. Now you have to hold the button to start it. The dealer had the truck for a day trying to figure out what changed. They compared it to one that came off the line with the daytime lights activated and it started the way mine used to. After having it for a full day they said "sorry nothing we can do, that is just the way it will be from now on." Has anyone else experienced this?
Old 02-22-2013, 09:48 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
well that sucks...i think thats crap..sorry, nothing we can do...welcome to the forum
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 02-23-2013, 12:49 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Somehow they disabled the tip start, I didn't think it could be disabled. Hopefully one of the resident techs will chime in.
Big Red my old 2011 Sport
Old 02-23-2013, 12:58 AM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Just for giggles, try unhooking the negative battery terminal for 30 seconds...then hook it back up. I've done this to reset the system when quirky things pop up after an install. Might be worth a try!
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 02-24-2013, 10:02 PM
Thanks for the thought TVL. I tried it but no luck.
Old 02-25-2013, 03:30 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1648
Hopefully it will be a quick fix......Good luck.....
Old 02-25-2013, 05:30 PM
Kman521 Kman521 is offline
Vehicle: 2013 Dodge Ram
Kman521 is on a distinguished road
I don't have the button start but when I bought my 13 SLT I could just do a quick momentary twist of the key and it would start.
I had the dealer install a factory brake controller and program the computer and now there is a delay when I twist the key before it starts to crank. Once it starts cranking I can let go and it will continue to crank until it starts.
At first I thought I was imagining it but it' is definitely delayed.
It's not a big deal but something isn't right.
Old 04-03-2013, 11:39 PM
grubscrew's Avatar
grubscrew grubscrew is offline
Vehicle: 2013 dodge ram 1500 crewcab
Color: Copperhead pearl
grubscrew is on a distinguished road
Wondering if anyone has had any luck fixing this problem? Got a brake controler installed last week. It use to be foot on the brake and a quick press of the button it would start. Now after the install foot on the brake and press the button it goes to accessory, then a second push will start it. Or foot on the brake and hold it until it starts. Not the end of the world but annoying non the less. Took it back to the dealer and after 2 hours they tried telling me it was normal but refused to go check a new one on the lot to prove them wrong
Old 04-04-2013, 08:11 AM
Coastline's Avatar
Coastline Coastline is offline
Vehicle: 2013 Ram 1500 4X4
Trim Level: Laramie Longhorn
Rep:15
Coastline is on a distinguished road
Mine started doing this also after I took the truck to the dealer about a problem with the radio. He said he did reset or something (I knew more about the radio than he did). Every since then the push button start is delayed.
