Old 02-24-2013, 01:55 PM
MOTH3R MOTH3R is offline
Color: Maximum Steel Metallic
Rep:19
MOTH3R is on a distinguished road
As much as I normally hate Apple, having an iPod is the way to go for this.
Old 02-24-2013, 03:19 PM
Rep:2642
Ram is a bit different
i have been looking for the video demonstration by a Harman Kardon representative, it goes into some detail of using the radio, ipod, & usb modes
Old 02-24-2013, 03:44 PM
Cookie Monster Cookie Monster is offline
Vehicle: 13 1500 Laramie Crew 6'4
Trim Level: Laramie 8Speed 4x4
Color: True Pearl Blue
Rep:71
Cookie Monster will become famous soon enough
You can't create a playlist on the Uconnect just play one. what you need to do is create the playlist on your PC you can use programs like itunes or windows media player. save the playlist file to the SD card then use the browse and browse by Playlists (page 182 in Uconnect Manual) and select your playlist. You then should be able to select Shuffle and it should shuffle between songs within the playlist.
Old 02-24-2013, 05:07 PM
Coastline's Avatar
Coastline Coastline is offline
Vehicle: 2013 Ram 1500 4X4
Trim Level: Laramie Longhorn
Rep:15
Coastline is on a distinguished road
I know i have to create the playlist on a PC but, how do you do that. I know it's got to be simple but I can't figure it out and I have googled it and can't come up with anything on how to create the playlist on flash drive or SD card. If you can help out with that I'll gladly sing at you next wedding
Old 02-24-2013, 05:23 PM
Zixxer Zixxer is offline
Vehicle: 2013 Ram 1500 Sport
Rep:35
Zixxer is on a distinguished road
I used windows media player to generate playlists and than copy the entire folder structure to my 64GB SD card. You can edit the playlists in notepad and copy only the files you need but it was just easier to make what I wanted and copy everything.
I use standard .WPL playlist saved in the playlist folder...it worked.
2" Mopar Lift/285/65/20 BFGs/DB Corsa Exhaust/Mopar flares/Lo Pro Tonneau/Line-X Premium/Ez Down tailgate/Catch-Can/Moe's 87mm TB
Side Molding/345 Emblems/Husky Splash Guards/Honeycomb Grill/25% Tint/Silver Rally Stripes/Crux Rear Camera and VIM
Removed - Air Grabber - filtering is not very good
Old 02-24-2013, 06:04 PM
Coastline's Avatar
Rep:15
You would have been just as well off speaking in German. Explain it to me like you would explain it to a 3 yr. old.
Old 02-25-2013, 12:14 AM
Rep:71
Here are directions to creating a playlist in WMP.
http://windows.microsoft.com/en-US/w...r/11/playlists
Once you created the playlist you need to us Save As and save it to your SD card. you also need to make sure all your music libary has been copied to the SD card.
Old 02-25-2013, 07:28 AM
Coastline's Avatar
Rep:15
Now that looks doable. Thanks a million...so do you have a "playlist" ready for me to sing at your wedding?
Old 02-25-2013, 11:27 AM
Rep:71
Glad to help. let us know how it works out for ya.
