Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Dodge Ram Decals
Old 02-23-2013, 05:21 PM
karfever karfever is offline
Vehicle: 2013 Laramie 4x4
Color: Black/Silver
karfever is on a distinguished road
Default 2013 hard wire at rear Mirror?
On my 2010 1500 I was able to easily hard wire my escort at the rear view mirror. My 2013 Laramie is much different. I don't see a pink/green tracer wire there and cant get my tester to light on any of those pins. Is there an ignition switched power wire and ground at the mirror?
If so what are the wire colors?
Thanks in advance for the help!
Old 02-23-2013, 06:42 PM
K9ENDY's Avatar
K9ENDY K9ENDY is offline
Vehicle: 2013 Dodge Ram CC
Rep:175
I ran mine into the fuse box, super easy but steveschaedel did a write up on this back in January step by step. Here is the link and good luck to ya!
http://www.ramforumz.com/showthread....ire#post996255
Old 02-25-2013, 10:22 AM
Color: Black/Silver
ANYONE? Need wiring detail at the rear view mirror plug
Old 02-25-2013, 04:25 PM
SteveO's Avatar
SteveO SteveO is offline
Trim Level: Sport 4x4
SteveO is on a distinguished road
I tried to do this as well. I found the right wires.. But couldnt figure out how to do it cleanly with the covers they use on the rear view. I ended up knocking the mirror off the window and had to take it in to Dodge the next day to have it re-installed.. Im gonna suggest running the cord to the fuse box and hiding the cord up in the headliner.. Good Luck.
Old 02-25-2013, 06:55 PM
K9ENDY's Avatar
Rep:175
I ran it to the fuse box, up the fire wall zip tied to other stuff, through the weather stripping and onto the lower left side of the dash for a low profile look. Was kinda worried about it picking up the 360 degrees but it's working like a charm and I am picking up the radar from normal distances with plenty of time to slow down if needed (my foot only gets a little heavy on the freeway, town and rural posted speed limits are where they should be around here). I've got it hooked in to the 10 amp fuse for the ignition so it is on/off with the vehicle.
Old 08-07-2016, 07:48 PM
Leo Belair Leo Belair is offline
Vehicle: 2014 Ram 1500
Leo Belair is on a distinguished road
Hi,
I need wiring for rear view mirror with Mic.
Thanks,
L.
Old 08-07-2016, 09:52 PM
hemifyd's Avatar
hemifyd hemifyd is offline
Color: Charcoal Grey
hemifyd is on a distinguished road
I had mine wired into the center interior cab lights. Comes on when the truck is turned on.
HEMIFYD
Old 08-07-2016, 10:51 PM
Hi,
But I need to hook up the mic on the mirror for the hands free to work.
L.
Old 08-08-2016, 11:16 AM
Snowgoose's Avatar
Snowgoose Snowgoose is online now
Vehicle: 2016 Ram 1500
Color: EcoDiesel
Rep:30
Snowgoose is on a distinguished road
On my 2016 Big Horn the black wire is ground and the pink with yellow strip is ignition switched 12V
2016 Ram 1500, EcoDiesel, Big Horn, 4x4, Crew Cab
ARCHOIL 9100 & 6200 and PRI-D & PRI-G Dealer
Old 08-08-2016, 07:36 PM
Hi,
Thanks for the reply.
I need to know where to connect them to, Drivers side pillar has an empty harness. Is that the correct spot to splice into ? What about the mic wire, there I 3 from what I read in the posts.
L.
