HOW TO: Disassemble Door Handles for Paint - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-18-2013, 06:48 PM
FSTASFCK FSTASFCK is offline
Vehicle: 2010 Dodge Ram Big Horn
Rep:108
FSTASFCK will become famous soon enoughFSTASFCK will become famous soon enough
Default HOW TO: Disassemble Door Handles for Paint
Ok, I took the day to figure out how to get the chrome section of the door handle off in order to paint it...I'm not going to get into taking the door panel off and where to drill the holes in order to access the screws because there is a how to already on that. And for the record, drilling the holes makes removing the door panels so much easier!!!
Now, you are going to need a 7/16" drill bit and a T8 Torx bit to complete this process. On the backside of the handle you will see the single screw hole for the screw that mounts it to the door...
You will drill 2 7/16" holes on either side of the main screw hole and just a little off center towards the middle of the handle...
Once the holes are drilled you will see the 2 T8 Torx heads. Unscrew these screws...
Now start to pull on the chrome part of the handle on the side that you removed the two screws. DO NOT TRY TO PRY FROM THE OTHER SIDE, YOU WILL BREAK THE NOTCHES HOLDING THEM IN. It doesn't take a whole lot of effort...I don't have a pic of this but if you look at the backside of the chrome piece you will see the plastic notches holding it on...
Once you get that side popped out, there are a couple of "clips" on the top and bottom of the chrome part in the center of the handle, once these are undone keep pulling from that side so you do not bend (read break) the plastic notches holding the handle on the other side.
The chrome piece will now be seperated from the actual handle so you can paint it. I have not started painting yet as I am waiting on some color match paint but I will start the prep process tonight and follow up in this thread with how it turns out.
Just be careful and take your time and you will have no issues and no broken plastic
Old 02-19-2013, 10:04 PM
Rep:108
REALLY...after all the threads I looked at wanting to paint the chrome handles and not 1 reply...hmmm
Old 02-19-2013, 11:49 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
lol. I was actually very interested in this thread. I just am waiting to see the finished pictures
Sean
Old 02-19-2013, 11:54 PM
Rep:108
It will be a little bit... I ordered the mopar color match paint since I have used it already and the color is near perfect with my truck...doesn't show that it has shipped yet so who knows...but I have sanded the handles all down and just waiting to get the paint and will do a final sand then start the painting process...they have sanded down nicely tho
Old 02-23-2013, 09:11 PM
white4x4's Avatar
white4x4 white4x4 is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:80
white4x4 will become famous soon enough
hell if i had known that they came apart they easy i would have done that, i just bought some of the black plastic ones off ebay 45$ shipped an they were brand new all 4 of them so it was easier and cheaper than painting them, but thats my .02, good little "how to" tho and a very cheap mod someone can do at home for cheap
Old 02-23-2013, 09:15 PM
Rep:108
If I wanted them black that would definitely be easier...but color matched is my plan...and with my "odd" paint color there isn't any other way to get them besides painting myself...sometimes it's such a pain having this color...
